If you press 7 0, it will come up with two 7's then 0, also whenever you press any button, the volume display stays on screen, if you press input or settings, it jumps back and forth on the options, then goes back to the original option, you have to get very lucky to select what you want.
SOURCE: Screen Rotation
you have to drop the device back to its native resolution 800x420 for the rotate function to work
Why do you need factory reset if you managed to get into settings?
Testimonial: "There was another account besides mine, but it was deleted, now its only my account and I have forgotten my pin and I can't access my settings from my home screen"
You have got to hold down the power, volume up and down at same time, when its obvious it turns on the release the buttons and then ur boot menu should appear
read it here
Digiland DL700d Hard Reset Procedure
I essentially started about a month and a 1/2 agone and i have gotten a couple of test for a whole of $2,200...this is the bestcall I made amidst pretty some time! "grateful to you for giving Maine this incredible possibility to profit from home. This similarly cash has changed my existence in such an excellent measure of courses, to the point that, bypass on you!".......GOOD LUCK Click this Below connectHERE ?????? . www.green.jobs67.com
