14 inch electric chain saw /portland
These Portland brand chainsaws were manufactured for Harbor Freight. Like all Harbor Freight products, getting parts for them is a bit of a challenge, as the products are only available for a couple of years and then no longer manufactured, with parts no longer being available. You can try contacting Harbor Freight and inquiring as to whether parts for your particular model are still available or not. -
Contact Harbor Freight Tools
1-800-444-3353 6-6PM PST
SOURCE: 14 inch electric chain saw throws chain off
If a new chain ::
make and model is important here, as are guide bar length
a particular chainsaw, may be available with 12,14,16,18,20,22,24,26 inch guide bar,
likewise different saws (even from different makers) use the same size of chain
a chain for this saw may be sold in a variety of lengths or
may be sold in the longest length only and require links removed to suit smaller bars.
back to the store, with the saw, for confirmation
If an old chain::
stretched way beyond safety, replace
SOURCE: how to put the chain back on a 14" Poulan electric
Remove the cover that cover the rear of the chain bar.Now,loosen the nuts that attach the bar and slide the bar reward.Now set the chain in the slotted part of the bar,pull it forward until there is abut 3/8 of an inch slack in the chain an tighten the nuts.Re-install the cover.
SOURCE: just got a homelite 33cc
Yes you do! The ratio is 50:1 fuel to oil. Be sure to use a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Be sure to use fresh fuel and mix the two in it's own container. Be sure to shake the container thoroughly each time just before refueling to prevent oil starvation in the engine. Don't make up more than one gallon at a time unless sawing is your business. Hope this helps!
SOURCE: where can I find a Product Manual for McCulloch
McCulloch manuals are available as PDFs at their site: http://www.mccullochpower.com/node7877.aspx . Enter the model number and click Search. The direct link to the MCC1514 manual is http://www.mccullochpower.com/ddoc/MCCO/MCCO2008_USen/MCCO2008_USen_MCC1514-6096210915_966993001.pdf .
I hope this helps.
