Question about Toshiba Televison & Video
Toshiba 49L3750VT half screen bright, other half dull.
This vertical split is a perfect 50/50, the "dull" half is a softer tone than the bright half. Nothing in the manual to help. I have tried changing the "Location" setting between "Store" and "Home" but this makes no difference (I was thinking Demo-mode). It does this on all inputs. Any ideas? Can I upload or embed a photo here?
    Top Expert:
  • Toshiba Master
  • 10,402 Answers
Bad high power board or main control board
Posted on Oct 10, 2019
6ya staff
SOURCE:
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: Grey line horizontally across screen
yOU ARE HAVING A PROBLEM IN HORIZONTAL CIRCUIT OR IN YOUR POWER SUPPLY kindlyu take your T.V tO A QUALIFIED TECH to repair it.ypur problem could be a faulty capacitor ,flyback or horizontal output transistor.
Posted on Feb 25, 2007
Jim Krause
  • 1779 Answers
SOURCE: VIZIO P42 plasma, half screen ok, other half showing blank
First you have to check if voltage and data are ok at the Y sustain board and the Y driver boards are not running hot. Even if you know how to replace these panels you must have a scope to adjust the v-set up and v- down. Not just a simple PNP. Trouble shooting a plasma is not a short time process to do it correctly. Please let a service center look at it for you.
Posted on Feb 18, 2009
Anonymous
SOURCE: how to remove "in retail store mode with settings" message
Question What should I do if my TV is stuck in Retail mode? Answer Your TV may have been set to Retail Store mode, which is mainly used on the shop floor.
For home use, we recommend that you set the TV to HOME mode, which will allow you to change the settings.
To change to HOME mode follow the steps below.
  1. Press the 'MENU' button on the remote control to access the main menu.
  2. Move the cursor down to select INSTALLATION and move the cursor right.
  3. Move the cursor down to select PREFERENCES and move the cursor right.
  4. Select LOCATION and move the cursor right.
  5. Move the cursor up/down to select HOME and press the 'OK' button for confirmation.
  6. Press the 'MENU' button to exit the menu.
Posted on Nov 14, 2009
Kiri Amarakoon
  • 290 Answers
SOURCE: Best picture settings for toshiba regza 42RV500e
Go to menu on your remote control and select picture setting and try selecting "default" setting to seeif you like the color, if not adjust contrast to about two thirds of the way and brightness to your liking and color to about the middle.
Posted on Jan 17, 2010
elisafeb
SOURCE: leapster 2 screen to dull to see
The leapster 2 screen is so dull you can hardly see the writing and programs. Very dark in colour. You can see colour arounf the edge of screen but the darkness overpowers the screen.
Posted on Jul 19, 2010
Tn50x81 vertical black lines moving across the screen
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 01, 2011 | Toshiba TN50X81 50" Rear Projection...
I have a toshiba 52 in projection tv Model number 50H82 and the picture is really blurry with lots of vertical lines
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
Feb 27, 2011 | Toshiba 50H82 50" Rear Projection...
I have 1 37" Sanyo LCD TV. The screen is split
bad screen driver boards, it can sometimes be corrected by tapping it on the side that is affected NOT ON THE SCREEN I MEAN ON THE TOP. The only way to cure the problem is replacing the panel.
Nov 14, 2010 | Sanyo DP37647 37 in. LCD TV
Leapster 2 screen to dull to see
Jun 06, 2010 | LeapFrog Leapster 2 Learning System
I have an RCA 50 inch projection tv that all of a sudden looks like the picture is warped on the screen.I can not make screen adjustments with the remote to solve it.
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 13, 2009 | Toshiba 50H72 50" Rear Projection...
Dull picture on laptop but cursor is still bright
The screen brightness is automatically adjusted by your laptop's Power Management configuration in the Control Panel. Depending on your laptop's brand you might not only have the Windows power management, but also a proprietary power management application within the control panel or in your Start Menu programs usually listed under your computer's brand name. For example a program folder called "Toshiba" under Programs for a Toshiba laptop. Anyway, I would start there. Usually you can set up the screen brightness according to whether or your computer is plugged in or working on battery. Good luck! :)
May 22, 2009 | Toshiba Satellite A105-S4004 Notebook
New lamp, now color variation, dull picture and overheating
it sounds like if your tv is a dlp the colorwhele is stuck
probibly because a after market or faulty bulb has melted it
get serviced imedietly
Jan 23, 2009 | Mitsubishi WD-62531 Projection Television
Toshiba 50h82 convergence issue
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Dec 11, 2008 | Toshiba 50H82 50" Rear Projection...
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Televison & Video Logo
35 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
