Otherwise it seems to work well except for the fact it is now displaying closed captions even though in my settings it shows that CC option is clicked off.
SOURCE: Sharp Aquos LCD TV 52"
Its in the TV Setup. The Cable box will output the Closed Captioning on
Line 20 or 21 of the Picture - this is just at the top of the TV
Picture where you can't see it. The TV Menu should have a choice of
closed Captioning like CC1, Teletext, etc. and one of them should be
selected. After exiting the menu, you should start seeing Closed
Captioning
on the tv.
SOURCE: connecting asus M51V to Panasonic TH-42PX8A plasma via HDMI
Hi
Make sure your TV does indeed support the resolutions you are trying to use. Some low quality HDMI cables can also be troublesome in higher resolution so try one you are sure to work.
Regarding to the desktop only being extended when using the RGB cables, try bringing up the desktop properties window, select the TV as the primary monitor and select "Use this monitor as Primary monitor". You might have to drag the windows Taskbar over to the other monitor, just rightclick the taskbar, uncheck "Lock the Taskbar" and drag it over to the other monitor.
Hope you find this solution helpful, and please rate it if you do so..
best regards,
Karl
SOURCE: Panasonic Viera Closed Captions HELP
Just use he remote and push the cc button or the display button until cc off appears on the screen
SOURCE: Cant turn off closed caption
I have this same problem...TC-P42X1...can't turn off the closed captioning
SOURCE: Turning off Closed Caption
Are you using a cable/satellite box or just basic cable service?
When you go to the menu what options become available to you?
If the following options are present-
smartlock
setup
cc
If not try to press both the volume buttons on the front of the TV at the same time and see if the above options become available.
If so use the channel down button on the front of the tv to scroll to "cc"
Once CC is highlighted use the volume + button until it says CC off.
If these menu options don't become available please reply what options are shown.
Good Luck.
