Televison & Video Logo
Ellen Purvis Posted on Aug 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Set my lg tv and cable box to turn on at 6:15 they both turn on but there is no signal.
mikemail1
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 95 Answers
  • Posted on Aug 21, 2019
mikemail1
Expert
Level 2:
New Friend:
Night Owl:
Answers
95
Questions
0
Helped
30553
Points
286
. not enough information to suggest a fix.
5 Related Answers
Anonymous
  • Posted on Dec 21, 2008
SOURCE: no signal when hooked up with a digital cable box
I had the same problem and had the cable guy out and everything thinking it was my box. I figured it out by myself here is what i did to fix it. I have the vizio 32 inch hooked to an hdmi cable and through the cable box i had the aspect ratio on 1080i and i should have had it on 720p once I switched it I havent had the problem since.
Anonymous
  • Posted on May 05, 2009
SOURCE: Basic Cable (no box); signal "in" to DVD Recorder (from TV)
Problem solved via tech support for Toshiba- thanks!
Anonymous
  • 85 Answers
  • Posted on Aug 20, 2009
SOURCE: my LG tv shows no signal with hdmi cable to hp
First you need to state Mac G5 model and MacOS 10.?,? and whether the connection is VGA or mini-DVI. (I'm at 10.5.8.) I would not be helped by LG model other than to know if it is HD 1080 or 720. I'm going to assume you have MacOS 10.4 or later but most should apply. Apple>>About This Mac>>More info...>>Hardware>>Graphics/Display and read more about the display. Digital connection will give you more info. Close the Info but even with VGA you should be able to go to Apple>>System Preferences...>>Displays and have 2 windows--1 for the built-in and 1 for the external. If the latter is off screen, press Gather Windows. On the external display Turn on Show Displays in Menu Bar. This will let you control Mirroring and Resolution. You will need to pick a resolution your TV can do 1920x1080 1280x720 or possibly less to get started. My MacBook has all of those. I usually do not use mirroring and 1920x1080 gives a good pixel match to my DLP. On the external, turn on overscan if you need to put the menu bar on the screen or off if showing maximum of photos. You need to sync first, then play with other things. -Ken
Anonymous
  • 50 Answers
  • Posted on Apr 27, 2010
SOURCE: "No signal" sign on TV screen using HDMI selector
it sounds like a refresh issue, double check you selector and make sure it fits the refresh of the tv. i had this once with a sharp where the tv was 120hz and the selector was 60 and it created a no signal and when it did come in it was jumpy. if you have a 120 tv then selector should be the same.
Jaime Hernandez
  • 2351 Answers
  • Posted on Sep 24, 2010
SOURCE: My LG Plasma 42PC3D turns on and off repeatedly. I
Your plasma TV has a power supply 6709900019A. These power supplies failed due to defective capacitors. See the picture below and check the capacitors mark with the red lines. There are 10 capacitors that should be replaced even if they do not show signs of bulging/swelling on top.
The value of the capacitors is 3300uF/10V but you can use 25 volts as long as they fit in the space provided by design.
Does the LG 32LC7D television receive digital signals
Almost all TV's can receive digital (over the air) signals as long as you have a powerful enough antenna. This is different than the digital signals from cable TV, which are processed through the cable box then input into your TV (best way is HDMI connection). Check your TV manual for how to set up over-the-air broadcast capabilities.
2answers
We have a TV LG 55la620t-da problem
Many of these newer tvs have problems with capacitors that go bad before anything else. I too have had this problem and was able to find online someone who knew which capacitors to change, after I changed the two small capacitors the set worked fine and still is. So I would search your model # for this fix in some of the repair forums out there.
No hd signal on my lg32lc5dc tv
Answer a few questions to try to resolve this issue:
What is signal source for HD you are using? (cable box, sat box, receiver in line, antenna).
Where on the set are you connected? (HDMI, HD component input on rear or?)
Does if not a box used the set have a built in HD tuner?
We have a LG42lx6500. when you turn it on after being off for a few hours the picture colour is distorted for a couple of minutes before correcting. At times you can see the individual pixels. Sometimes...
Hello
Make sure TV is on the correct channel or input. Check the cables for correct routing from TV to any other devices. Check cables to ensure they are tight and secure.
An analog signal converted to high defintion resolution will cause lines, blurriness or fuzziness in the picture. Change the resolution to a lower or native setting using the media device (cable box, DVD,). This may be an issue that requires a service call to cable provider.
A problem on one channel may just be a error on that channel. If using an antenna, it might need to be adjusted in order to ensure good signal strength. For digtal channels, go into TV Menu. Check the DTV signal. Weak signal can cause picture distortion.
If another device is being used such as a cable box, DVD player or VCR switch between devices and test picture. Check routing of cables that are used to control the image. This should be a series of red, white and yellow cables.
If a VCR with a cable box, make sure the VCR and TV are set to the correct channels for video signal to pass through. If problem is still occuring, try another set of cables. bad cables can cause picture distortion.
Bad cables can cause picture distortion as well. Try another set of cables. If picture is better than when using the cables replaced, this was the issue. If cables are not an issue TV may require service.
When turning on the TV, the on light is on, however it's not connecting to our cable system and the screen sits blank. We had the cable company come out to check the box and he informed us the box is...
The tv Tuner signal board it is dying,that why tv requiring to turn on and off a few times to get the tv incomming broadcasting signal work,to get a picture.The tv Tuner signal board, that the board that take in the incomming broadcasting signal cable and other external devices plugin to it like a DVD players and games systems.Can u take things aparts and putting it back togther again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for to do the replacement.
Screen suddenly went to complete snow no video or audio
Well the LG tv is not getting the cable signal.Unplug the cable box about an hour.Replug the box let the software to upgrade the cable box.The LG tv should get the signal back as normal.Not,than the LG tv Tuner board have problems it dead.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Hi just got a LG dvd/vcr Model RC897T. I have it hocked up right, but i can't get it to switch over so that it would be seen on the TV. can you help
If a cable box is not required for cable signal reception, connect the cable line to the ANT. IN connector on the recorder.
If a cable box is required for cable signal reception, connect the cable line to the IN connector of the cable box. Connect a coaxial cable from the OUT connector of the cable box to the ANT. IN connector of the recorder.
To view or record a CATV channel:
  1. Tune the TV to the Recorder output channel (CH 3 or 4).
  2. Set the Recorder channel selector to the cable output channel. (Example: CH3).
  3. Select a channel using the cable converter.
With this connection, you cannot record one program while viewing another.If you are using a cable box to tune channels, it is not necessary to do Auto Channel Set.
No remote (LG or otherwise) works
The remote receiver in the TV set, or its associated circuits inside the TV are not working. This would be fully proven by trying another known working remote on the TV set.
Jerry G.
1helpful
LG TV renote not worknf on 4 new sets
If you have a cable box (otherwise known as a set-top-box) that you have to turn on when you turn the tv on, and you use to change your cable channels, the LG remote will not control it. The LG remote is strictly for the tuner built into the television, and is not capable of controlling the cable box.
You probably see "function not available" because you are viewing the picture on an external input of the tv (component, composite, etc). Your tv cannot tune stations in when it is set to an external input that you use to watch DVD's, cable boxes, games, and other devices. The tv is telling you that you can't change channels if it is on an input.
I hope this helps you...
Tv-- signal strength normal but signal on all channels "blipping" down intermittently causing freezing of picture. Have replaced aerial with high gain antennae together with aerial cable and...
When ever the picture freezes intermittendly the problem is usually poor connection on the signal line (antenna or connection on tv) or poor reception. Could be the tuner if the tv has one.To eliminate the tuner possibility try anther tv set if possible.
If you still cannot figure out the problem,let me know what kind of set up you have connected to your tv set.
Do you have a satellite or cable box and if you have splitters.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
