Hi Richard, I sent you a link where you can buy a Power Supply Board for your Insignia TV 65D260A13
I hope it helps you
Greetings Franco Dosil
Hola Richard, te envio un link donde puedes adquirir una Placa de Fuente de Alimentacion para tu TV Insignia 65D260A13
Espero te sirva
Saludos Franco Dosil
https://www.google.com/url?sa=i&source=images&cd=&ved=2ahUKEwjRnJmX6r3kAhWxGLkGHS6YCnAQjhx6BAgBEAI&url=https%3A%2F%2Fwww.tvpartstoday.com%2F19-64S03-001-Insignia-TV-Module-power-supply-p%2F19.64s03.001.htm&psig=AOvVaw3uDyDVg9ffNShUTaUqVv3i&ust=1567915011934020
https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcSuYKG0uqAEzIt8m8q75ToamCXYN6ticOW7Grpi_ygME8EPHwHy
Need the model number please
Testimonial: "The Model # is: NS-65D260A13 for the TV. I did not want to pull the board for its model number if one is not going to be available"
SOURCE: no picture
Had the same problem, Insignia 32 would click on then go off. About 6 months ago I found (somewhere on the net) a guy who explained that he changed blown capacitors. As I recall he even posted a picture. I found the blown capacitors and replaced them with larger capacitors (less than $20) problem solved...
But now my screen image is showing only half a picture and is pulsing on a off.
I think I'm going to make a Wii commercial......GL
SOURCE: INSIGNIA 26" LCD TV > > MODEL# NS-LCD26F
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: Green power light blinking all the time on TV
After changing a defective capacitor, my TV still would not power up. After using a solution I found on this site, I held the power and volume up button down on the TV itself for several seconds, the TV powered up normally. I did notice that you had to do this while the timer light was flashing. Doing so after it went out was not effective. I initially only replaced one capacitor which was noticeably defective, and the flashing green timer light eventually returned. I will be replacing all 7 capacitors and resetting the TV. As mentioned above, the capacitors may look good but in fact may be defective. These are high temp caps which breakdown under a load but function normally when cold. Several people have mentioned replacing the capacitors didn't fix the problem. It appears that you must replace and reset using this method to repair some of these TVs.
Find out the cause of the fried board.
