Question about Mtd Garden
WHAT YEAR WAS THIS MTD GOLD MADE...S/N 1C120B30159
I WANT A MANUAL FOR MTD GOLD 42" RIDING MOWER
Not available from Fixya. Try Googling (MTD)(S6V01)(manual) without parens.
Aug 15, 2016 | Mtd Garden
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
MTD GOLD LAWN TRACTOR WHEN ENGAGE PTO AND LOWER DECK . SLOWS DOWN TURNING BELT SLIPING
Belt is worn out and needs replacing or maybe the jockey tensioner is not operating on the belt hard enough to prevent slippage. If its all in good condition get a good DIYer or mechanic to have a look. If not its down to your local garden machinery shop.
Apr 27, 2015 | Yard Machines MTD Gold 185 HP Lawn Tractor...
Wont start gas
squirt some starting fluid in the carb see if it will startif not chek for spark at plug if fireing check gas for water after that remove float bowl from carb clean it out replace plug and it should start
May 18, 2013 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
How much oil do I put in my Mtd Gold self propelled mower
most push mowers are about a half a quart
May 11, 2012 | Mtd Garden
Need spindle assemblies for a 2000 vintage, 600 series, 42 deck. and belts
Go to partstree.com and enter the info it asks for IE: Mtd mod #13aj771s004 then follow what it asks for.
its worth a try
Apr 30, 2011 | Yard Machines MTD Gold 185 HP Lawn Tractor...
Require replacement clutch for MTD RH 135\105 B
Hi I am Kelly and welcome to FixYa. I am having difficulty crossing your model number. Do you know what year you purchased the mower?
I have found a close match at this site using model year 1995
http://www.jackssmallengines.com/help.cfm
You need to choose these drop down window options in the order listed on the site:
"Search for Model"
MTD
MTD GOLD
13-Lawn Tractors
1995 Models (There are 3 of them... so I would bet you will have to find the closest match to your model)
After all of the above FINALLY the model diagrams will come up.
There is another drop down menu just above the Zoom + or - buttons for the sub assemblies.
I am thinking this is what you were looking for but... if not please check your model number again and I will continue to assist you.
Thanks for choosing FixYa.
Kelly
Jul 21, 2010 | Mtd LAWN MOWER PART # 642-04032 TINE...
Garden Logo
49 people viewed this question
Top Mtd Garden Experts
dannydoesita
Joseph Mueller
Joseph Mueller
p38arover
Level 1 Expert
Are you a Mtd Garden Expert? Answer questions, earn points and help others
