Question about Westinghouse Televison & Video
Tv comes on to display Westinghouse logo than turns off sometimes gets a reception before shutting down was told it was a safety feature so what needs repaired or replaced
6ya staff
SOURCE:
Anonymous
SOURCE: Westinghouse LTV 19w3 shuts off
The same thing was happening to mine and the problem was in the power supply. Apparently, there was a loose connection causing it to go in and out. The round connector end that plugs into the monitor has two prongs on the inside. I was able to bend each prong toward the center with a thumb tack so that it would have a tighter connection, and it now works fine. Unplug from wall before working on the prongs.
Posted on Feb 23, 2009
Anonymous
  • 87 Answers
SOURCE: light engine
hold menu and input or device button at same time for 5sec. Let me know what blinking code you get. 3-2 6-1 etc.
Posted on May 25, 2009
Anonymous
  • 115 Answers
SOURCE: COLOR PROBLEMS
yes a difficult lesson to learn who ever the manufacturer. I would take it to a repair man and get a quote, maybe its cheap fix maybe its worth just getting a new one.
Posted on Jun 22, 2009
Anonymous
SOURCE: TV turns on...displays Polaroid then shuts off...
You have a bad power supply, call a local tv repair man 2 fix it for ya. Unless you think you can do it urself, but recommended a professional takes a look, dont want to damage anything else in the tv or hurt urself
Posted on Oct 07, 2009
Testimonial: "Bad power supply....got it! I will be calling Mr. Fix It, thanks a lot!!"
Ivan
  • 308 Answers
SOURCE: acer at32012 shut down
Power supply. Try replacing it. It is modular.
Posted on May 08, 2010
Testimonial: "tnx for fast response Ivan The first thing I did was to try onother power board and that is not problem I have three of these same models in shop all with identical problem Tnx again Jim"
Tv shows the westinghouse emblem then goes black
If the westinghouse logo comes up on screen then instantly shuts done its caused by a failed transformer on the inverter. the Guys over at www.tvrepairworld.com can assist you with a replacement inverter or replacement transformer for westinghouse models.
Apr 02, 2012 | Televison & Video
Screen go back to black after the westinghouse logo displays.
Westinghouse? A model number might help me help you---does sound remain or never make it on?
Mar 14, 2012 | Televison & Video
Power light comes on,clicks before picture comes on then shuts of
Yes, it is either that or the "Startup Circuit" is faulty usually it is the associated relay. Thats the clicking sound you hear. When you turn on the TV, the relay is activated along with a timing transistor, the Relay has to make contact within a certain time frame. If the contact is not made during that time frame, the TV shuts down. This is a safety feature in all TV's. If you can get a schematic it will show you where the relay is or, after you unplug the TV and wait 15 minutes, you can take a look inside at the main circuit board, sometimes they mark the area with either "START UP" or "SHUT DOWN" and there you should see a relay.
But a new one usually has to be soldered in.
Mar 26, 2009 | Televison & Video
Westinghouse lcd 26 inch
I found that with my Westinghouse SK26H240S lcd tv. that when you turn down the blacklight feature you get a hum thru the audio. so I just turned the blacklight feature to the max and the problem went away, no more audio hum.
Sep 11, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Mitsubishi WS-55807 television
this tvhas a built in safety feature, fuse, sometimes you can hear a faint popping noise when you turn the tv on and it shuts down. This feature was designed to prevent power surges from hurting your tv any more than it already is. You will have to have someone repair the small problem you have now and reset the tv. 10% of the time you can try holding doen the menu button for 10 seconds and/or unlpugging it for 4 hours to do a hard reset. This hardly ever works though. It will probably cost you about 200 to 500 to fix it. sorry
tom
Jun 05, 2008 | Mitsubishi VS-50111 50" Rear Projection...
TV shutting off
try this part first 5600110347 you can get it at www.vancebaldwin.com
Jan 31, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Dec 27, 2007 | Westinghouse LTV-19W3 19 in. LCD...
My HDMI ports won't work on my Westinghouse tx-42f430s TV. I have things plugged into 3 ports and they all quit working. I had to connect the composite cales to get my TV to work.???
FOUND A SOLUTION! (at least in my case) thanks to some creative Google searching...
Apparently the HDMI ports can get into a state where they are unable to negotiate the input signal properly. The way to "clear" the ports and allow the HDMI signal to be detected is to perform a "reset" on the unit.
Just turn the set off using the power button on the right side of the unit. Then, press and HOLD the power button for at least 10 seconds, then release.
The set should turn on and essentially do a "reboot" where it displays the Westinghouse logo. After that your HDMI ports should be functional again.
It worked for me :-) Best of luck..
Nov 06, 2007 | Westinghouse TX-42F430S Television
TX-42F430S Lock up on power up
I have a similar problem with my TX-42F430S; Mine freezes when changing from Comp 1 to Comp 2. unpluging and waiting was the only fix. Just recently my TV just started turning off(after about 30min of watching) and the led will flash blue. I need to unplug for about 10min before it works again. Getting frustrated and I have contacted Westinghouse to send for repair. only had the TV for 3 months; connect to Roger Explorer HD box.
Nov 02, 2007 | Westinghouse TX-42F430S Television
Televison & Video Logo
35 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
