Question about LG Washing Machines
My Fuzzy Logic WF T8018TP only one of the two bags collect fluff
4 Suggested Answers
6ya staff
SOURCE:
jimorris77
  • 411 Answers
SOURCE: I want to remove my LG Fuzzy Logic WF-T8018Tp
.I am not a repair professional. I am a 78 year old man
who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Dec 02, 2009
Seena Mary
  • 11 Answers
SOURCE: I have a LG Fuzzy logic for a year and a half now,
certain materials give off fluff and some others seem to attract it. you can try putting in similar materials together and avoid mixing turkish bath towels, blankets and jackets and such clothes having fluffy lining with normal clothes. Also try selecting higher water level (overriding the automatic selection) manually. Once when i had fluff on clothes, it turned out to be tissue paper from my child's jeans pockets. After cleaning the filter bag, run the machine empty at maximum water level every week. Hope one of these will help solve your problem.
Posted on Jan 17, 2011
reliableservice
  • 314 Answers
SOURCE: My washing machine has been
yopu mmioght need to replace the drain pump
Posted on Sep 04, 2011
I have a LG 3step Turbodrum Fuzzy Logic WF-T8018TP when I put on the auto/off button it keeps on showing me the error PE how can a fix this
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
May 14, 2015 | LG Washing Machines
Fuzzy Logic 8.5Kg WF-T857 Turbodrum. How do you clean your machine and can you replace the fluff pockets?
Your owner's manual will show the amount of bleach your size tub requires. Run the machine on normal cycle that you use but do not add washing powder or fabric softener, only the bleach.
When the cycle has ended, open it up and allow to air dry.
The lint filters are replaceable and are available from your nearest LG service center or distributor.
Apr 16, 2015 | LG Washing Machines
My LG WF-T8018TP Fuzzy Logic is not draining water
kindly check drain motor some forgot items are in side...
Feb 12, 2014 | LG Washing Machines
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
I have a LG Fuzzy logic for a year and a half now, model WF-8071TTP top loader. it seems that after washing all my clothes are full of fluff. I have cleaned out the filter bag, and all little filters at...
Jan 17, 2011 | LG WFT1071TP Top Load Washer
Washing Machines Logo
55 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
