Carol Cutler Posted on Aug 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My HP 2300 will not pull paper to print I have reset the machine What else could cause this
martin hogg
Level 2:
Scholar:
  • Expert 157 Answers
  • Posted on Aug 22, 2019
martin hogg
Expert
Level 2:
Scholar:
Answers
157
Questions
0
Helped
76449
Points
263
It appears you are not alone with this issue, here is a link to the question and response from hp support community
https://h30434.www3.hp.com/t5/Printers-Archive-Read-Only/Laserjet-2300-paper-jam-in-top-cover/td-p/5943470
5 Related Answers
Ajkill
Anand Kumar
  • 2035 Answers
  • Posted on Jan 04, 2009
SOURCE: lexmark z2300 printer won't pull in paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Walid M Sayed
  • 313 Answers
  • Posted on Mar 16, 2010
SOURCE: HP 2300 jams when duplexing multiple pages.
try to replace the pickup roller and sepration pad (if ther are old)
Anonymous
  • 202 Answers
  • Posted on Sep 19, 2010
SOURCE: I am having HP 2300
Hello .
First select the configure device menu by up & down arrow keys in display select them by pressing green button find no of copies in sub menu change this value to 1 & set them by pressing the green button.Your value set to no of copies to 1 & your problem will be 100% resolved.
Bizhubman
Ben
  • 108 Answers
  • Posted on Sep 30, 2010
SOURCE: hp lj100a keep pulling several sheets of paper
If it is pulling all the pages at once, the separation pads are dirty or worn out. If you remove the drum/toner you should be able to see the feed tire that pulls the paper in to be printed on. You will also see small gray or black rubber pads, these separate the pages. You will need to clean these with mild detergent, but do not use alcohol. If this helps for a little while or not at all the separation pads will need to be replaced.
Testimonial: "on the money on procedure to clean the wheel"
alanha
Axiom Media Support
  • 409 Answers
  • Posted on Sep 12, 2012
SOURCE: HP LASER JET 2300 52.00 ERROR
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
4. Replace the engine board.
Tallon41
Hp design jet 2300 paper detect problem. even after removing the print paper roll from the machine it says remove paper but there is no paper inside
Hard Reset:
  • With the printer turned on, disconnect the power cord from the rear of the printer and also unplug the power cord from the wall outlet.
  • Remove USB cable, if present.
  • Wait for 2-3 minutes, press and hold the power button on your printer for about 30 seconds to remove any additional charge.
  • Now plug back the power cable straight to a wall outlet without any surge protector or an extension cord (This is important) and then plug back the power cord to the printer.
  • Turn on the printer and wait till warm-up period finishes and the printer is idle.
Tallon41
Print 4.374 x 5.75 sharp 2300
Envelopes must be run from the bypass tray at the side of the machine. touch the paper trays on the touch screen. Set the bypass to envelope and com10. when you go to print, make sure the paper type is set to envelope under printer preferances.
Problems with duplex printing
So you're saying it will only pull paper from tray 1? This is likely because there is some setting that makes it think the paper in the other tray is not "normal" -- either thick paper, or a different size, or recycled. Check the paper type and size settings in the printer's menu, and also check the settings in the print driver.
The other tray that you want to duplex from is capable of duplexing, right? On some printers you can only duplex from specific trays.
Why my hp deskjet 2300 paper jam
please your printer in paper tray in out of paper and open the head couver and so the fixing in apaer. and printer is off and next time on and aply print is ok.
HP 5550 Print issue
When you removed the jammed paper , the jam paper sensor was not reset or positioned correctly. The reason the machine was sending two pieces of paper thru at once was probably due to the paper feed sensor. A lot of H'Ps do this. Try re-aligning the tray and if you pulled the paper out and heard a grinding noise, the whole feed unit is probably out of time.I would only re-install the software as a last resort, since your problem was caused by hardware, not software. Scrivitron
k24674
Grand Canyon Tech
Grand Canyon Tech
