Remove water connection and test to make sure you a re getting water to dishwasher. Then check water level sensor these are sometimes a small plastic piece that moves up and down with the water level. Make sure it is not stuck. Some are a stationary sensor that you may need to clean. Next ,I would check to see if you are getting power to the fill valve. Turn on D.W. and check for voltage at fill solenoid which should be right where the water connects to the unit. If you have power solenoid may be defective.
Hope this helps
Bob
Thanks will try this out and get back if i dont come right
SOURCE: Royal ORCA 3500 paper shredder
orca 3500: reverse works but auto run does not. Green Light is on, bin is empty but will not shred paper? Any suggestions?
SOURCE: Bulb blown on Russell Hobbs CJ/AL28 microwave
Just open the top cover and find the location of the bulb , it may be in the right side near the control panel. Remove the bulb and get a similar bulb with the same rating from any electrical shop and fix it
SOURCE: missing recipe cards for Russell Hobbs Breadman JNR
I have the Breadman Jnr and I can send you the recipes but I'll have to type them all up.
Prepared to do this and send them to you for US$50.
Would you be interested in the service?
You can contact me via email: [email protected].
Bernard
SOURCE: account charge for playing 2 blizzard games online
There is no monthly fee for Diablo or Diablo II. Battle.net is a free service.
SOURCE: My Russell Hobbs microwave will not generate heat
If everything else is normal, the trouble may be a failed magnetron tube (the microwave source), problems on the control circuit board, or parts in the tube power circuit that are bad. It's also possible a door switch can be at fault, but this usually keeps something else (fan, turntable or light, most often) from running as well.
Microwave servicing is best left to professionals. There are potentially deadly voltages present, and a chance of microwave leakage if repairs aren't done correctly. Take the oven to a shop for an estimate, or just consider replacing it if it isn't a built-in, an over the range unit or a high-end countertop model.
