SOURCE: Battery Low indicator and Camera shuts Down
What brand of memory card are you using? Sandisc, Toshiba and Panasonic are the only ones that really work with the cameras. If using one of those trying resetting the camera.
Menu
go to setup
go up to reset
press right arrow
highlight reset
press set
If that doesn't work....Send it into repairs and they will send you an estimate on what it
would cost to fix it. Give them a call at 800-706-2534 option 2.
SOURCE: Camera turns off when taking picture
you just have to do this thats it and your problem is solved
the normal batteries some times you get it new but does not support.this is the only solution.
2800MAh batteries - fix your Fuji problems.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
SOURCE: I bought a moultrie MFH-i45s game camera used. It
Go back to the seller immediately, explain the problem to them, tell them you want to return the goods and ask them for a full refund.
Most likely, the seller had the same problem and because they couldn't easily find a fix, they sold it to make it someone else's problem. You are entitled to expect a 2nd hand product to work properly.
Your country should have consumer protection laws to back you up. Don't put up with this nonsense. Good luck
