Question about LG Cell Phones
My lg uh 5560 just flashes LG logo when turned on?
5 Suggested Answers
6ya staff
SOURCE:
POOJA RAJ
  • 47 Answers
SOURCE: windows xp black screen after lg logo solutions
Press the three key Ctrl+Alt+delete from your keypad when you see that black screen with cursor blinking,the scree will come up automatically or else try to switch the notebook in safe mode by following these instruction:
1. Turn on the notebook and keep pressing the F8 key from your keypad
2. You will find options like --Safe mode
--Safe mode with Networking
--Start window Normally
3. You need to select the Safe mode with networking option and then press enter from your keypad
This way you can get into the safe mode and you can easily use the notebook.
If the information helped you then please give me some ratings.Thanks
Posted on Jun 02, 2012
easybill99
Rani wadia
  • 996 Answers
SOURCE: lg-a341 flipphone stuck on white lg logo screen
reflash new files ,with lg flashing tools
Posted on Jan 23, 2015
Larry
  • 2800 Answers
SOURCE: My LG model 47LN5700-uh TV turns on, flashes the LG logo and then powers off, what should I check to see if it is defective?
I had the same model with the exact same problem last week in my shop, it turned out to be a firmware issue, went online downloaded the firmware to a flash drive and into the TV and it worked fine after that, not saying this is your problem but I had checked both the power board and main and found nothing bad so that is when I reverted to the firmware issue
Posted on Nov 26, 2017
amarjit_love
  • 8 Answers
SOURCE:
1Check power board capacitors if swelled then replace them ,
2 check led output voltage at connector on power board. If voltage down come back from led penal then one or more leds fused.
Please replace it.
3 it may caused power board defective too.
Posted on Oct 01, 2018
I have a LG tv model number 47Ln5750-uh it has the stand by light on and when I turn the tv on it shows the LG logo for a split second then the screen goes back wounding if you may know what part needs to...
Please replace it.
Oct 01, 2018 | LG Televison & Video
Will LED power supply fix my black screen on TV?
Chances are you have bad lamps in the panel...you will need to take the front cover off and get under the panel and test them and see if some are bad, if they are replace the strip...good luck as its not all that easy to get the panel off and back on without damaging it, use extreme care handling it or once you get the lamps working the panel can be damaged and then it has to be recycled as it can't be fixed
Mar 19, 2018 | LG Televison & Video
Your Main PCB is faulty. LG is version specific. There are additional letters after the "UA" in the model number located below were you found that one. The complete model number is also located on a small rectangular sticker near the edge of the TV on the back. Use the entire number when searching online for a replacement.
Nov 26, 2017 | LG Televison & Video
I have an LG model #55ln5750-uh my tv when i turn it on it flashes lg then goes dark i changed t-con board and power supply and still does the same
Please check the LED back lights strips, it is a common problem for your TV symptom.
Yes, when you power down the power, the back lights may flash on.
Apr 24, 2017 | LG Televison & Video
Model lg42ln5700-uh. Why does it turn on, displays the LG logo, then turns off?
Hi Tony
Sorry.... previous was a lazy answer... at the end of a long day.
Your TV attempts to turn on, finds a problem, then turns off!
This is because the TV has a smart electronic power supply that can sense certain problems. Like overheating or it senses excess current draw from other circuits.
Everything is fine until about the time the logo appears then shuts itself down.
First:
Check that the tv is getting ventilation.
No blocked air holes, as they use convection to cool the insides. Hot air out top, cool air in bottom.
Take a photo on your iPhone of the rear connections.
Remove all connections from rear in case they are adding to the problem.
Tap or slap the back a few times on startup to see if movement plays any part in the fault. Loose Connectors.
A modern tv works very much like a desktop computer.
No internal nobs or adjustments any more.
It's all CPU, Memory, Video memory on a circuit board.
If you feel comfortable with opening it up and checking inside then you might see the problem and be able to fix or replace a faulty module.
But... if the tv has just one large circuit board, thats little tougher to replace (& expensive)
Second:
With the back removed, check for loose connectors / wires,dust. Cockroach residue or nests, cause copper track shorts on circuit boards.
Follow the AC power lead to where it attaches to the electronics.
This will be the switch mode power supply.
This is where most modern electronics devices get their problems.
Look at the Electrolytic Capacitors on this board. The small round tin cans with an x on top.
Do any of them have a bulge in the top?
If so, the cap is probably Bad & needs replacing,
They also sometimes leak brown fluid from their bottom onto the printed circuit board.
You would either replace or repair this electronic module.
Turn Power On.... all working
Good Luck
See
https://www.youtube.com/watch?v=W8KTiFeN9k8
Sep 21, 2015 | LG Televison & Video
My lg rumor wont get passed the lg logo, it simply turns off only to get to the lg logo again, its been doing that for the last 2 day, i had it running than i check my txts and it turned off again and...
FREEZING OF PHONE
Hi, when a phone randomly freezes, it means that the phones memory is faulty or when an application you downloaded has virus.
What to do is this,
You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Jul 07, 2010 | LG RUMOR Cellular Phone
My lg chocolate won't turn on, just keeps flashing the Verizon Logo
Flashing the logo means that the LCD is fine and kicking. You must get the phone's firmware reinstalled. The reason of flashing Verizon Logo is that it cant read or follow the instructions beyond the logo stage. So, give it the stuff to read or follow. Reinstall the firmware and you will find that everything moves smoothly.
Dec 11, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Cell Phones Logo
Top LG Cell Phones Experts
William Norris
William Norris
Sheldon Dedek
sheva420
sheva420
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
