Hi Lisa, as you say, it is very likely that the Laser reader may be dirty or the reader's progress locked
Consult a specialized technical service
Regards Franco Dosil
Hola Lisa, por lo que comentas, es muy provable que pueda estar el lector Laser sucio o trabado el avance del lector
Consulta a un servicio tecnico especializado
Saludos Franco Dosil
SOURCE: cd won't play
Easy fix, look at the front of your CD player, you should see a little pin hole, insert a paper clip into it and the pop the CD tray open.
SOURCE: kenwood kdc-w6527. ERROR 05
clean the cd lense with a cd cleaner, had the same thing and it works perfect now
SOURCE: Kenwood DPX-990MD CD and Mini Disc player.
latin america frecuency setting 531 mhz to 530 mhz
SOURCE: My 5 Disk CD player doesn't work. It wont read any
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
