SOURCE: dirty and light copy of my Kyucera KM 1505 copier machine
Clean the optical parts (lens,mirrors),and the poligon motor mirrors.
SOURCE: I have a Kyocera Mita 1635 Copier and it's giving blank copies
FIRSTLY CHECK THE DRUM UNIT CONNECTER ,,LOWER UNIT IS LOCKED OR NO YOU LOCKED THE LOWER UNIT AND THEN CLEAN THE CHARGER OR CHANGE THE KARONARO WIRE
SOURCE: i am using Kyocera 1800. Copy is getting lighter. i want ot check whether toner is adding or not
Most likely the drum is getting worn out. Your manual should tell you when it's time to change the imaging drum, and most modern copiers have a setting in the display panel the tells you how much life is left in %.
