Hi, even though the two jets appear to be spraying upwards, the force may be diminished by partially blocked nozzles. To check remove the debris bag and observe jet action as cleaner is held near water surface. the action must be strong enough to shoot well into the air. If not, then often a piece of wire can be inserted into jets to dislodge the debris. you may have to do this one or more times.
the other cause of insufficient jet pressure is that the feed hose to jets has ruptured or the zip strip retainer has broken. unit must then be partially disassembled.
When my polaris wheels stopped spinning it was the water jet which spins the turbine was clogged. The in-line filter had failed and some small debris had passed through to clog the jet. Easy fix to take off the top cover then take off the turbine cover and examine /clear the hose (clamped on by zip ties) and the plastic jet.
1. debris in the water management system (hoses inside the cleaner)
2. black gears in cleaner need replacing (360/380)
3. belt kit (polaris 360/380) or drive shaft need replacing (180/280)
4. teeth on inside of wheels are worn out (polaris 180/280 only)
