Question about Sanyo Heating & Cooling
Where can I get a filter for the sanyo khs0951 mini split a.c. unit?
    Master:
  • 578 Answers
Https://lmgtfy.com/?q=khs0951+filter
Posted on Aug 25, 2019
5 Suggested Answers
6ya staff
SOURCE:
alex_salve
ALEX SALVE
  • 78 Answers
SOURCE: My Sanyo KS1211W split air conditioning unit does not cool
u r compressor is not functioning,sure u need the service technician
Posted on May 17, 2009
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
Anonymous
SOURCE: ON/OFF button doesn't work on Split System Air Conditionr KHS0951
My AC split unit runs good for a wile then the outside turns of ( fan,compresr ect)
Posted on Aug 07, 2009
Horace Gardner
  • 125 Answers
SOURCE: Hello We just installed a Sanyo KHS1271 mini-split
The condensate drain line was not properly installed. Make them pull the wall unit and correct the problem.
Be persistant until you are satisfied they have the problem corrected. Do not pay any additional money. If they do not correct the problem then report them online to the state board of heating and air. Fill out their requested complaint form and follow thru with a second complaint if you do not get total satisfaction from the contractor that installed the unit.
Hope this helps.
Posted on Sep 23, 2011
Have a Sanyo split inverter AC unit. On turning it on, operation lamp blinks and unit does not cool. Please help.
The blinking is an indicator that it needs service. Call a technician! Ask if they are experienced in mini split systems. You can check the air filters. Check the outdoor coil to see if its clean or covered up with dirt. And at the breaker or disconnect, turn off power, wait 5 mins, and turn it back on. Then give it 3-5 mins to see if it will reset itself. If this don't work, call a tech/service provider! These units are troublesome to troubleshoot.
Jun 06, 2015 | Sanyo Heating & Cooling
Have a Sanyo KS2472 split inverter unit. On turning it on, operation light blinks and does not cool. Also compressor does not seem like it turns on outside. Please help.
HOW DO I CHECK AND CORRECT THE FREON LEVEL FOR MY SANYO KS1271 A/C; WHICH IS NOT BLOWING COLD AIR?
Hire a tech it will be cheaper and safer. You may have a capacitor that is bad and not starting the compressor.
Aug 22, 2014 | Sanyo KS1271 11,900 BTU Ductless...
Error c5
C05 error indicates no communication between indoor and outdoor units and remote control. Replace the remote batteries with fresh duracells first. If that doesn't fix the problem, verify the indoor and outdoor unit are wired together properly. If still no love, a tech will need to come visit. CALL SANYO TO SCHEDULE A TECH IF NEEDED. Mini-split units are new to the industry, and not all HVAC techs are good at fixing them.
Mar 30, 2014 | Sanyo Split System Air Conditioner
Hope this helps.
Sep 23, 2011 | Sanyo Split System Air Conditioner
Need replacement remote for Sanyo Model KS0911 Air conditioning unit
Call 954-771-1415 ask for Ivan* universal remote for mini splits
Jun 03, 2010 | Sanyo Split System Air Conditioner
May 08, 2009 | Sanyo 18KS52 Air Conditioner
Heating & Cooling Logo
29 people viewed this question
Top Sanyo Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Dennis Boxerman
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
