Question about Toshiba Televison & Video
Need help programming universal remote to Toshiba DVD player
6ya staff
SOURCE:
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: SHARPER IMAGE 8 IN 1 TO TOSHIBA HD DVD PROGRAM CODE NEEDED
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
Anonymous
SOURCE: Toshiba 23HLV87 - has built in DVD player
my dvd is saying no disc in the player i have a 23hlv87
Posted on Sep 13, 2008
Anonymous
SOURCE: Need a code for a VCR/DVD player for my universal remote
Magnavox VCR. The Phillips universal remote lists the following codes:0330, 0430, 0534, 0324, 0224, 0124, 0247, 0230, 0125, 0093, 0598, 0830. Doesn't seem they have much control of which code gets used on which model. Start in the middle and work both ways to the ends. Make sure to post back which one you find that works.
Posted on Jan 15, 2009
Anonymous
SOURCE: Code to program my RCA Universal Remote to work my Jwin DVD Player
i need the remote code for a JD-VD5503
Posted on Dec 24, 2009
mamaface53
SOURCE: magnavox dvd player and universal remote need code please
have rca universal emote need codes to progam magnavox dvd player please help thanks
Posted on Jul 17, 2010
Need codes for he universal remote to program to Toshiba DVD player SD-1800
Use the code search provision of your universal remote to seek a suitable code. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Jun 03, 2016 | Toshiba SD-1800 DVD Player
What is the universal remote control code
Toshiba SD7300 DVD Player
Wade, Check the attached links,instruction and guides, you will find the code. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RCA universal remote control codes for RCU800 HC1310 RCU300 and other...
4 Digit Universal Remote Codes For DVD Codes For Universal Remotes
http://www.remotecontrolscenter.com/remote-controls/toshiba
http://codesforuniversalremotes.com/
Apr 05, 2016 | Toshiba SD7300 DVD Player
Moved and lost my remote, but can't find a code in the Universal Remote booklet for this brand.
astar dvd 3100 remote code Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your astar dvd 3100 remote code question. Get free help, tips ... Ican't program the dvd to a universal ... dvd to a universal ... My VCD can play on DVD-3100 DVD player, but DVD disc can play on it. It always show "bad disc" ...
hd 3100 DVD & Blu-Ray Players Questions & Answers - Fixya
www.fixya.com > Forum > Tags > hd 3100
toshiba HD-A35 region unlock I am looking for an unlock code for the region ...nexxTech (EDP 3100) DVD Player Can't get my nexxTech (EDP 3100) DVD ... i need to find where i can buy a remote in b.c. canada i need a remote for my astar dvd ...My VCD can play on DVD-3100 DVD player, but DVD disc can play on it.
Lost Remote, Need Code For Universal Remote jx
www.hivmr.com/db/jx97xsd37ad83fd1mksxzxkf88ca3fa9
I recently moved and lost my DTV remote, I have a Phillips PM625S 7-device .....Need remote code for ASTAR tv's .... Need remote code for Sylvania Model 6719DF TV/DVD/VCR combo. ... DB:2.37:Remote Code For Vizio Vbr120 Blu-Ray Player 88 ...Would like to programme my SKY remote but can't find the code ...
Jan 18, 2016 | Astar DVD-3100 DVD Player
I have a GE 24944 Universal Remote that I need to program to a Toshiba HD DVD (A3) Player. No code works from the manual. Can anyone please help?!
If you have a GE universal remote, you can use its "code search" function to find out whether any code in its library can control your Toshiba player. If nothing works, you may have to try another programmable remote as all programmable remote do not contain all codes.
Oct 28, 2014 | Televison & Video
I need the code list for a Universal remote Toshiba CT-90158
Try to enter code 664 it is the only code in my book for a JVC dvd player
Aug 15, 2012 | One For All Televison & Video
Remote control for Toshiba 20AF45
Just buy one universal remote control which have set up codes for Toshiba, or an orginal one from the authorised service center for Toshiba.
Mar 27, 2012 | Toshiba 20AF45 20" TV
I have a universal remote and need the code for a magnavox dvd player to program the dvd player thank you
To get the code please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Please
Provide model of your remote
device to be programmed (VCR,TV)
Make name(toshiba,sony)
Thanx
Jul 28, 2010 | RCA RCU404 Remote Control
Need the code for one for all universal remote to
The code for a URC-3021 to control a Toshiba DVD player is 0503.
To setup your URC-3021 for the DVD player, these are the steps:
1. Turn on your DVD.
2. On the remote control, press DVD once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once. The device should turn off.
Hope that helps.
Oct 25, 2009 | One For All URC-3021 Remote Control
I need to program a universal remote for a Toshiba SD-K510.
it is 1110 the code for Toshiba SD-K510 it works on mine Toshiba SD-K510 the code on mine universal remote
Jun 07, 2009 | Toshiba SD-K510 DVD Player
Televison & Video Logo
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
