SOURCE: Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
SOURCE: BRAVIA TV KDL-40V2500
i had the same problem and the only way i could solve it was to disconnect power from the tv, let it "reset" then it would be ok for a bit. the problem went away entirely when the cable company updated its software for its hd box. might be coincidence....
also, pre-update, the resolution wouldnt automatically set correctly. If I turned on the tv to a hi def station, it would set to 480 and only set to 1080 when i changed to a normal station then back to the hd. then it was fine. again, after the update from the cable company this went away.
SOURCE: No sound on pc connection
HDMI outputs from devices such as DVD players do carry both video and audio, but the HDMI output from your computer video card only carries video. You'll need to connect a cable from the computer sound output to the TV as well.
SOURCE: BOSE 321 DVD movie movie
Sounds like you are using a component cable(red,green,blue) rather than an HDMI cable.
Component cables are fine to use but if one of the 3 cables is disconnected, loose or bad, you may see blue video.
Check for loose connections or bad cables and make sure the proper color is plugged into its matching color.
SOURCE: How to enable "Bravia Sync" on KDL-40V2500
I also have the same problem and was wondering if you ever found out the answer to this problem Peter?
