SOURCE: Broken Tractor clamping lever (KX-P1150)
try calling the panasonic office in the states 201-392-4808 and ask for a dealer near you to help you fix the problem
SOURCE: The smallest clamp (bottom clamp) is broken.
Try www.BogenTripodParts.com for that part. There is listed the widest selection of Bogen parts and support more models than any other web site I’ve seen. There are losts of pictures to help find just the right part.
SOURCE: I need insruction BOOK for Bosch Rotak 344 GC LAWNMOWER
Here you go:http://www.bosch-pt.co.uk/boptocs2-uk/modules/oragetblob.dll/Rotak34_manual.pdf?db=ocsr55_s041&item=OCSHEIMWPDF.v$m$d$lobvalues.r55&id=90005,10446,20&filename=Rotak34_manual.pdf
Just copy and paste that into your browser it will take you straight to the pdf for it.
SOURCE: LAWNMOWER INSTRUCTIONS ROTAK 34/36
click that and it will take you straight to the pdf file for it
Door catches.
One of the latches may have broken off
and is not lifting the other latch clear of the housing. Remove from
any power source, remove the cover of the cabinet. Slacken off the
clamp mechanism and ease the clamp over the guide to allow the door
to open. When a new door lever is in place, the door may be easily
adjusted by slackening off the screws that clamp the door
catch/actuators in place whilst holding the door closed and then
tightening the screws. The rear of the door may be adjusted by
slackening the lower door hinge screws and adjusting as required.
I
hope that helps.
