Question about Sansui Televison & Video
I have a Sansui tv. The universal remote will work on every function except changing the channel. I have tried 2 different remotes. What can I do?
6ya staff
SOURCE:
Bill Heronemus
  • 308 Answers
SOURCE: remotes don't work
The problem is likely with the remote receiver itself, p/n 0778000003 - It's about a $15.00 part if you can replace it yourself.
Posted on Feb 11, 2007
ShadeTek
ShadeTek
  • 81 Answers
SOURCE: Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Posted on Nov 10, 2008
Anonymous
SOURCE: no universal remote works with my rca tv model l40fhd41
I helped a friend choose this TV at WalMart. Since I know of the remote issues with Directv, etc., I recommended that he get the Philips 6 in 1 Learning remote for $20. The learning part is the key. I believe it is so new that all stores may not have it yet. It is not on the web site. I have used the Philips learning remotes with 100% success. Give it a try, you can always return the remote (but I believe it will work).
Posted on Aug 06, 2009
coetzee_phil
  • 139 Answers
SOURCE: Unable to pair a Philips Universal remote with Sansui TV
Hi
1032, 1051, 1052, 1054, 1061, 1075, 1079, 1091, 1140, 1157, 1173, 1203, 1209, 1232, 1237, 1258, 1287, 1337, 1339, 1340, 1375.
Regards
Phillip
Posted on Oct 17, 2009
charlie-th
  • 13 Answers
SOURCE: how to program a universal remote for the Sansui
It may mean that the code you entered is incorrect. Try these: 0135, 0310 and 0394.
Posted on Jul 14, 2010
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
How can I get a code for my Sansui TV?
Codes are stored in the remote. If you do not have a Sansui remote, you will have to obtain a universal remote and use its code search feature to find something that works. If a search through all codes stored ion the remote is unsuccessful, you may have to try a different universal remote as all universal remotes do not store all possible codes.
Jul 03, 2015 | Televison & Video
Sansui to DTV converter box
The model number you provided is for the Sansui tv remote. Are you trying to set up a universal remote that works with your new tv?
Nov 26, 2013 | Audiovox Code Alarm Pt-6c/goh-3bl98 Alarm...
I am trying to get the aux outlets to work on the tv how do i do that?the universal remote i have is not putting the tv on that channel and i have the red white and yellow jacks installed in fron of the tv...
Try using the channel buttons on the front of the tv to go below channel 1. If this doesn't work you will need the original remote or you could try a different universal remote. You can use an RF modulator, available at walmart or radio shack, to feed the signal through the antenna jack on the back of the set.
I hope this will help you.
Bobya.
Mar 07, 2011 | Sansui DTV2700 27" TV
My universal remote went out and somehow the tv-a Sansui-got switched from channel 3. How can I get it back to channel 3 so the converter will work? I tried changing channels manually at the tv but it...
Look in the owner's manual for instructions on having the TV scan channels. Make sure the converter is on before starting the scan. If that doesn't work, you'll have to buy or borrow a universal remote to take care of it (enter 3, 03 or 003 on the remote control). This will happen every time you remove power to the set, whether it is unplugged or you have a power failure, so start saving up for a new remote control.
Dec 07, 2010 | Sansui 27" TV
Hi
Regards
Phillip
Aug 15, 2009 | RCA RCR311B Remote Control
New remote won't program to switch to cable input.
That's a problem with universal remote controls. Often they don't control every function of the TV. They just don't have the buttons needed to control everything the original remote did. You'll have the most basic controls - power, channel and volume up and down - and maybe a menu button. But you'll frequently find other things don't work, like switching inputs. There isn't anything you can do except try all the codes for your TV brand and see what each button does. You might find that the buttons have different functions depending on which code you've entered. You might also look for another brand of universal remote that has more functions available.
May 23, 2009 | Daewoo Televison & Video
Sansui channel program w/o remote
You should be able to just use the channel buttons on the TV itself. Go lower than 1 and it should go to video 1 or 2 ect. If this doesn't work there should be a menu button on there too. You use the channel buttons and volume buttons to move the cursor once you get into the menu.
Hope that helps.........
Jun 30, 2008 | Televison & Video
NEXXTECH 2 IN 1 BIG BUTTON Universal REMOTE CONTROL TV code for sansui tv
Have a solution for you.Turn your TV on then Press and hold 'P' on remote until light stays on. Press device to be controlled (TV/Cable) light will flicker but stay on. Now keep pressing channel up (up to 300 times) until device changes channel. Then press Enter to save code. Hope this helps
Jun 08, 2008 | Big Button TV Universal Remote
CODE RETRIVAL FOR A SANSUI TV MODEL
I lost the remote to my Sansui TV and can't remember the model number. can I get a remote to replace it?, the tv was bought in 2004
Nov 19, 2007 | RCA RCR311B Remote Control
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
