Possible source of a manual if you can identify model.
http://www.powermate.com/productmanuals.php?cat_id=3
SOURCE: Powermate PM0535000-01 Manual
powermate went out of business , but this might help let me know http://www.powermate.com/contact.php
SOURCE: in need of manual for a coleman PM0435003 Powermate Generator...
try Play it again sports
they have a large network of used sports gear and network of stores that get all inds of used stuff
They are individually owned so be persistent
SOURCE: stalling on my coleman 6250w portable generator
ajust the float in your carb (bend the brass tab in that the top of the needle valve touches)and clean this needle valve. the bowl can be removed with a 7/16 box wrench on the bottom brass nut that is also a needle jet (clean this jet ,some models it is just a jet, others it is ajustable and needs to be 1 turn out to start then ajust wile running hot untill it stops surging) the problem is not allowing enough fuel to fill the float bowl
SOURCE: need manual for my Coleman Powermate generator
Get model number and go to: http://www.powermate.com/productmanuals.php?cat_id=3
SOURCE: need instruction book for coleman powermate clean 1500
The hose connection I believe is for hooking a hose up and running it into a bottle of cleaner. The cleaner is mixed with the water when it is sprayed, The knob on the bottom adjusts the strenght of the solution. Most washers have the same setup.
