Question about Miscellaneous
Husqvarna hydrostatic transmission is slipping and wont go up small inclines. what can I try before removing and draining transmission, if anything?
    Master:
  • 578 Answers
Is oil level ok?
Posted on Sep 02, 2019
    Habit-Forming:
  • 121 Answers
Look for the screen filter and clean the magnet
6ya staff
SOURCE:
Heal lever won't press down to engage transmission on hydrostatic transmission
Hydrostatic Drive Problems?? - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
May 30, 2006 - Hydro-Gear Transaxle:218-3010L I got this tractor as part of the deal when I ... After spraying the heck out of it and pressing the brake pedal down several ... I pull on the handle in the back and it moves the lever but still won't move. ..... while in the air and turning the wheels with the transmission engaged? mtd lawn tractor wont pull hills
Oct 18, 2009
briggs trouble
Jul 5, 2008
Peerless transaxle repair, Husqvarna mower
Oct 13, 2006
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Missing: heal
HYDROSTATIC TRANSMISSIONS - Small Engine Information
smallengineinformation.com/?page_id=370
Jan 14, 2016 | Garden
MOWER WONT MOVE
Drive belt broken or slipped of pulleys, hydrostatic drive filter(s) plugged. Should be one or those, Roger. Follow the drivebelt with your hand (disconnect battery to be safe) and see if it hasn't slipped off the engine drive pulley, idler pulleys, or axle pulley. If you tractor is hydrostat, may be time to replace filter.
Aug 09, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna 2038
if this is a hydrostatic chang fluid and filter see if it wont improve
Dec 25, 2013 | Husqvarna Garden
My tractor won't go up any grade or incline.... it just gets slower and slower until it stiops.
HI
Im sure you have a hydrostatic or an automatic forward and reverse right well your ****** is on its way out when it warms up it likes to crawl in this case even if you attempt to check oil or even try draining and putting in different oil its a tough one ****** is expensive
Joe
Joe
Sep 09, 2012 | Husqvarna YTH2454 54in 25 HP Lawn Tractor
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Jul 30, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
When i cutting grass on a level surface the ride is smooth, however when i attempt to go uo a slight incline the ride is rough. Why?
It could be fuel related when you incline. Either not enough gas in tank or float is not set up rite or fuel filter is clogged and not letting sufficient fuel flow to carb. Good Luck...
Aug 24, 2011 | Husqvarna 22HP VTwin Hydrostatic 42" Cut...
A friend has a YTH2454, 07-08 and it just returned from a $500 service from the local dealer.Immediately it was noticed that the unit made a whining noise and did not climb the small inclines in the yard...
very common husqvarna problem if you read through these postings daily. that mower is actually made by AYP and that is about right price for a new tranny, inability to climb slight grades is the first sign. you can search eBay for folks selling hydrostatic trannies off NOS and there are mower junkyards out there if you google around. the tranny went out in mine after about 6 years and hundreds and hundreds of hours. if it only has a hundred hours you could check the the manufacturer about possible recalls, do that through a google search of the company name. changing the fluid is something i tried before scrapping mine, did not work and was a day of work to remove, drain, reinstall and bleed. I did get over 300 bucks for scrap mower on ebay, folks wanted the engine and the deck.
good luck
Jun 09, 2011 | Husqvarna Garden
Riding mower accelerates extremely slow and seems to stop on inclines
hydrostatic transmission failure, get your wallet out as they cost almost as much as a new mower
Apr 12, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a husqvarna 22 horse kohler 48 inch deck, the mower runs fine but when u first put it in gear it is very slow to move more so in reverse. and sometimes does not want to go up inclines, can this be...
generally signs of a failing transmission. yes you can replace it yourself in less than a day with the proper tools. get the whole thing up on jacks, drop the deck, remove the wheels, remove linkage and belt, remove bolts and the thing falls into your hands. problem is that you can buy a used mower for less than the price of a transmission. look around for a used or possibly rebuilt exchange transmission. google helps a lot.
Oct 17, 2010 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Miscellaneous Logo
32 people viewed this question
Top Miscellaneous Experts
Bill DeLisi
Bill DeLisi
Rachael Newton
Rachael Newton
Level 1 Expert
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
