If you put a new ignition switch in it is possible that the pins in the barrel are sticking and are not moving as they should.. take the key out and put powered graphite in the key hole and move the key in and out a few times and that lubricates the pins.. If it still will not turn then best check that the key is correct for the barrel .
I know this question is old but I recently encountered a similar problem with my 1995 323 BA and this may help someone else. Override the immobilizer by doing the following:
open the car via the drivers door put the key in the ignition turn the key to ACC now turn the key to ON repeat the last 2 steps X 12 quickly (ignore the indicators flashing and the central locking activating). the dashboard should be lighting up as normal. Now turn the key to START
You need somebody with a SLIM-JIM, which is what tow truck driver`s have. Are you a member of CAA? They or any other towing company will come to your car and unlock the door for you.
You can keep a spare key in a MAGNETIC BOX under your car in case ther`s a next time..
The spare key is the valet key, You can call the dealer and have them cut you new keys for you car. You will need the VIN number and your registration for the car. If it doesn't have chip in it, they can make it for you in a couple of minutes. If it has the chip in it, they will have to order it. Without the chip, the key will cost between $20 and $30 dollars.
