Question about LG Cell Phones
My LG iPECS UCS+ app does not ring at home OK in the office. The phone status goes from idle to busy but it doesn't ring
6ya staff
SOURCE:
Ekse
  • 13434 Answers
SOURCE: lG puk
Hi
The puk code is sim card spesific it comes with the sim card when you get it or you can get it by calling your phone service provider of the sim card to get the puk code.
if you have entered the puk code wrong too many times you will make the sim card useless and you will have to contact your phone service provider for a new sim card, it will probably cost.
Posted on Dec 27, 2008
Vit Avaya BP
Vitaly Kagan
  • 211 Answers
SOURCE: NEC Dterm 80
You will need a professional installer to do this for you.
Cross conecting and proper grounding required for any installations.
Posted on Mar 18, 2009
Anonymous
  • 44 Answers
SOURCE: My BB Pearl goes straight to missed call without ringing?
you might have the call dirversion set to on. check that in your call settings
Posted on Sep 02, 2009
clement chuma
SOURCE: can i have microsoft office 2010 home and business product keys ?
yes
Posted on Mar 16, 2013
Eddie Mundy
SOURCE: We are using LG Nortel
We've had similar problems with these systems, but have come up with a multilayered solution to deal with this. Most of these hacks are on either SIP trunks or ISDN trunks. Analogue trunks aren't generally affected as it's quite awkward to join the trunks to effect a call through the system. Here we go.
Disable voicemail remote access, change all voicemail passwords to non standard and keep changing them regularly. (Treat these passwords as you would a bank PIN).
In the toll exception tables, prevent calls out to 090 and 00 numbers which will prevent calls to premium rate and overseas. If your customer needs to call specific 090 number, you can enter these allowed numbers into the allowed table. If they require overseas, they have to accept that there is a risk of abuse.
If you're using SIP, make sure you get IP specific SIP trunks thereby preventing possible trunk hacking from offsite users.
To prevent unauthorised remote access, tie the customers router down to accept incoming requests only from a recognised maintenance IP address. Install a pc at the maintenance location that will act as a portal for mobile engineers who would access it remotely using PC anywhere or other remote management. Ensure you dont keep any saved databases on this remote PC.
Finally, ensure the system software is bang up to date and configure the new front end security. This requires a user name and password, and will lock the thing down for 15 minutes after 3 failed logins. (This also applies to users attempting to logon to the user portal)
Unfortunately this system isn't that secure out of the box. However if you think like the hacker, and configure accordingly, it's as secure as the best of them.
Posted on Jun 21, 2013
Re-installing Microsoft Office Home and Student 2010 (I have the product number) It re-installs about 1/2 way and then says: Setup cannot find Single Image.ww\ose.exe. Where can I find that?
  1. Determine the status of the Office Source Engine (OSE) service. To do this, follow these steps:
  2. Click Start, click Run, type services.msc, and then click OK.
  3. In the list of services, double-click Office Source Engine.
  4. View the option that appears in the Startup type list.
  5. If the startup type is set to Disabled, change the startup type to Manual. To do this, click Manual in the Startup type list, and then click OK.
  6. Try to install Office
Nov 18, 2014 | Microsoft Office Home and Student 2010
Why won't phone ring on incoming call?
Has this always happened?
Does it happen every single time? are you in cellular coverage, or does it happen only when you are in certain areas?
Have you got your call diverts set up correctly?
1. Find "Keypad"
2. Choose option
  • Choose one of the following options:
    • Divert all calls, go to 2a.
    • Divert missed calls, go to 2b.
    • Divert if unavailable, go to 2c.
    • Divert if busy, go to 2d.
2a - Divert all calls
  • Key in **21*+61411000321#
  • Tap Call.
2b - Divert missed calls
  • To select how long you want your mobile phone to ring before the call is diverted:
    • Key in **61*+61411000321**the required number of seconds#
  • Eg.:
  • Tap Call.
2c - Divert if unavailable
  • Key in**62*+61411000321#
  • Tap Call.
2d - Divert if busy
  • Key in**67*+61411000321#
  • Tap Call.
3. Return to the home screen
Jun 07, 2014 | Apple iPhone 5c
The phone stop ringing & I can't find the problem
(I am assuming you are a business.) You don't have a power problem, you have a line trouble to or inside the phone itself. Phones operate with two wires: tip or green wire transmit the outgoing sound (voice); the ring or red wire transmit the incoming ringing signal. Your ring side is shorting out after the first ring. This short can exist in a local central office that transmits your dial tone to you; can exist in the underground/airial wires to your buiding; can exist in a wire closet (a riser wire closet from the basement wire closet to your floor); or in your the very base of your phone. You can have your service provider to verify the ring side of your service at the basement equiptment room. They may charge to verify any further; however, it is common to have this short appear from the central office. If the central office is transmitting a good ring side signal, pay a local communications company to verify your line from the basement entry point to your office(s). NOTE: FIRST TEST OUT A CORDED PHONE AND SEE IF IT RINGS OK...THAT WILL ISOLATE THE TROULE TO YOUR PHONE IF THE CORDED PHONE RINGS OK. GOOD LUCK.
Mar 26, 2014 | Vtech OfficeMax - Vtech5.8GHZ DSS Cordless...
Problems in ipecs
The iPECS Communicator app has since been discontinued for iOS- Mainly due to it being unreliable.
The new UCS app for the newer iPECS systems is much more reliable, but unfortunately cannot be used on the old iPECS LIK system.
Jan 25, 2014 | Apple Computers & Internet
Need circuit board schematics for LG ipecs
Will you please send me the exact model number to this device?
google.com/+GopakumarGopalan
Dec 11, 2013 | Televison & Video
Setting the date and time
After selecting 1, type in the date mm/dd/yy (it doesn't appear on the screen) then press hold/save. Then type in the time again it won't appear on the screen press hold/save. It will then return to the main screen with the correct time and date. Hope this helps.
Oct 16, 2012 | LG Ericsson LIP-8012D 12 Button IP Phone
Does lg gx 500 support whatsapp
No unfortunatly it doesn't, it has a propriatory operating system. For a list of compatible LG phones here is a good list. Im not sure on how many LG phones are running on the Windows Phone OS. They dont have a LG list but still ok information
Jun 06, 2012 | iPhone Apps
LG CHOCOLATE: identify phone number of incoming voicemail
try transferring the calls from ur mobile to the voicemail when u r not available....
in call settings u might have an option of forwarding the incoming call after so many particular number of rings... forward the calls to ur voicemail numbers using this and then u ll have the numbers in ur recieved calls list.
this might work but is only a temporary solution
Jun 15, 2010 | LG CHOCOLATE VX8500 Cellular Phone
Cell Phones Logo
123 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
Sheldon Dedek
sheva420
sheva420
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
