The blades may not be turning because the blade assembly is not fully tightened onto the blender bottle. Another reason could be that you are not putting the blender bottle and blade assembly into the blender base in the proper way. For more answers visit the Oster Blend-N-Go My Blend troubleshooting page: Oster Blend-N-Go My Blend Troubleshooting
Your question landed in the Fixya.com category of Furniture. I re-categorized your question to the Oster Blenders category.
I found the following information regarding Oster blender built in fuses:
(Quote) The built in fuse protection has kicked in. To turn the blender back on, first turn the control knob to "Off" and unplug the unit from the wall. Then remove the jar from the base and free the blade of any obstructions. Next, press the external resettable fuse button on the bottom of the base. Wait 30-45 minutes for the unit to cool.
(End quote)
Source: https://www.oster.com/service-and-support/product-support/product-faqs/blenders/oster-versa/blenders-oster-versa-faq.html?faq=blenders-oster-versa-faq-Q-A-4
Question: My blender shut off during use. What happened?
A couple of things you can check.
Unscrew the glass jar from the bottom.
Check to see if the grey seal is between the metal blade assembly and the glass jar. I had this issue and it turned out to be that a friend had reassembled the blender jar parts after taking it apart to clean it.
inside the jar ring base (turn it upside down) you will see little white tabby things in the slots, at least one of them has to be lined up with the 2 small grey contact points on the base of the blender.
I had this same problem!!
you can contact me at [email protected]
The only thing I can think of is to try to repair the separated rubber with one of the special adhesives. This may not be physically, ie, damaged beyond repair, but if you think it might be repairable try something like JB Weld. They make an adhesive that sets up in 4 minutes. I have fixed some weird breaks with this stuff.
10-01-2009 Sara - see solution for rlaymon 1-9-08 "Top part of base broke off"by TanyaCS on 1-20-08 - good ideas. I just fixed mine - 2 hour job + half hour to put a new cord in. Like TanyaCS my broken coupling was rusted to shaft - used WD-40 twice and let sit - meanwhile took out motor and removed fan - kept screws and washers in order on workbench (kitchen counter) - the fan hole is "D" shaped - fan end of shaft also "D" shaped - I filed a "flat" on the other side of the factory "flat" (side of 'D' that is straight) - Used big pliers on broken coupling and adjustable wrench on on the "flats" on fan end of the shaft. Broken end came right off. New cord is 18 gauge extension cord capable of at least 6 amps. Cut off the un-needed end. Or order a replacement cord $4 when you order the rubber drive coupling $4, pin with slinger washer $3. Bet you also need new rubber feet - didn't buy for mine - wish I had. Bert
The part that you need is available from Oster, and their phone number is 1-800-334-0759. Their standard warranty is 1-year, so you would probably have to pay for the part. 4 years is decent for a blender - if you replace the part, an Oster will most likely last many years longer. While it is not uncompletely unheard of for a blender blade assembly to come unhinged, it is statistically infrequent - the replacement part will most likely last as long or much longer.
This just happened to me too, and I think I just fixed it. First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99). I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are. Remove the rubber skirt to reveal four screws that hold the motor in. They are way in there so you'll need a long screw driver. Remove the motor and unscrew the old coupling. Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck. I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks. If your blender is the same, remove the bottom nut, fan blade and two washers. This gave enough of a rod to grip to get the old coupling off. (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck! Hope that helps!
