Now would be a good time to read the manual.
http://www.ctmhomecare.com/PDF/Owner_Manual/User%20Manual-730.740%20USA.pdf
SOURCE: How do I tighten a
The generic steps involved are :-
1.Locate the knob on the base of the tiller. Turn the knob counterclockwise to loosen the bolt.
2 Adjust the tiller to the desired position. Push it forward or pull it backwards until you achieve a comfortable steering position.
3 Tighten the knob on the base of the tiller. Turn the knob clockwise to tighten the tiller on the scooter.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: Need owners manual for A ctm hs 740 mobility
go onto ctm homecare website and into rescource centre then dowloads and click on 740, regards, Bill.
SOURCE: Where can I download a manual for Mobility Scooter HS-360
Have you tried ( bt junkie ) you will need a bittorrent to use it i use ( u torrent)
SOURCE: intermitant drive power on my ctm hs 740 mobility scooter
The problem is going to be your motor. After extensive usage, the motor will give up internally and some times it will burn and melt the possitive/negative cables at its housing and it will give you issues with the batteries and the module.
Luis CTM: 909-590-1388
