The Kenmore 106.9552981 does not have a water filter for the ice maker. Sears Parts Direct has the parts diagram here: https://www.searspartsdirect.com/model/6bcxngyrj2-000582/kenmore-1069552981-refrigerator-parts . The models with a water filter will have the filter in the refrigerator compartment, on the back of the refrigerator or near the middle of the toe kick grill. So I checked the cabinet and refrigerator liner diagrams first. I also used the part search feature on the above page.
I hope this helps.
SOURCE: My kenmore refrigerator side by side
Sounds like it has a defrost problem. Check for thick frost buildup on the back bottom panel in the freezer first and let me know what you find so I can steer you in the right direction. Also, give me the entire model # from the sticker inside fridge.
SOURCE: kenmore Washine Machine does not drain
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch
SOURCE: KENMORE REFRIGERATOR 106.57024601
the problem is most likely the water valve behind the machine. it is closing too slow and letting too much water flow into the icemaker.
SOURCE: location of refrigerator water filter
The filter should be a canister somewhere in the line from your sink to the refrigerator. If there is no canister visib;le there then obviously they never installed a filter in the first place. I hope this helps. Don't forget to rate my answer. thanks.
SOURCE: can't locate the water filter. water has a bad taste
The base grille water filter is located below the freezer
compartment door. Depending on your model, you may have a filter that is installed behind the base grille or a filter that is installed through the base grille.
