Fridge was sitting for awhile,ran water til all air gone?
SOURCE: We own a RF267AARS/XXA refrigerator.
You'll have to read my in depth review on Epinions.com for answers. Sounds like you bought the updated version that over corrects the "too much" ice which jams the mechanism to where it breaks the unit. This is my second friggen Samsung as my 1st 4 door quatro was replaced under their lemon law. Spending $2500 I thought I was buying quaility, instead I bought greif. I'm still working with Best Buy to get Samsung to fix the icemaker with it's current problem which sounds like yours. Go to the Epinions website and look me up, my username is "walkerpkw" My review was posted last year. Read both my horrifying Samsung reviews. Something is very wrong with their engineering department. You'll find my email address on my profile page. I'd be happy to inform you if the get this fixed. I'm told it's the fridges computer board and they're redisigning another?
SOURCE: ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. [email protected] click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
SOURCE: how long does it take to make ice on a new fridge.
You should have ice by now.there should be a reset button the ice maker try and hold it till you see the ice maker advance. also make sure that ice maker is turned on.If these steps do not correct it set it up for service since it is new.
SOURCE: top of freezer not freezing
your cooling matchine get damaged,there having a cooling matchine.
