Hi M Smith, it indicates what model of Insignia it is, to know what type of Back Lighting it has
The problem you describe would seem more like the feeding stage of the Back Lighting, and may also originate on the T-Con plate
Comment the model, to find a better solution
I wait your answer
Greetings Franco Dosil
Hola M Smith, indica que modelo de Insignia es, para saber que tipo de Iluminacion trasera tiene
El problema que describes, pareceria mas de la etapa de alimentacion de la Iluminacion Trasera, pudiendo tambien originarse en la placa T-Con
Comenta el modelo, para buscar una mejor solucion
Espero tu respuesta
Saludos Franco Dosil
Sounds like LED strips are bad
SOURCE: i have a 32" insignia that turns on but a black screen ?
replace the power supply. their are 2 different part # for this model. you will have to take the tv apart to figure that out .
Advent
667-L32K5X-20W
SEE NOTES
BOARD, POWER (IF THE BOARD HAS 782-L32U25-200B)
Advent
667-L32K5-20C
SEE NOTES
Noes : There are two possible power boards used in this model. Order according to the number on the original.
SOURCE: Screen goes black.
I would say an inverter problem, you will need to have a qualified tech. do the repair. Julio [email protected]
SOURCE: sound but picture goes black after 10 min
is not the ballast. the problem is the control box
SOURCE: insignia 32 HELLP
PHIHONG - PSM210-417A-R
Rather than spend hours and time on the kit, these guys have the board in.
