If your Epson Stylus Photo 1400 has any problems, see these sections for solutions: ... The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning ... If you're printing on a CD or DVD, the CD/DVD tray has not ejected. ... Select a higher Quality Option or Print Quality and turn off High Speed mode.
SOURCE: epson stylus pohoto 830u paper feed
I'm afraid this series of printer (810 -830) doesn't handle heavy photo paper well - which is a bit strange for a so-called photo printer. If you hold each sheet and help it to feed it will work. But ...... for goodness sake. Your best bet is to sell it on e-bay and buy something that will handle heavy paper.
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
SOURCE: Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Testimonial: "tried blowing and dusting with a brush Now it comes on as normal - no flashing light but will only take paper about 2 cms then flashes paperjam"
SOURCE: Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets
1.
Open the paper support and raise the extension.
2.
Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams.
Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time.
Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.)
4.
Open the output tray and pull out the extension.
You should also follow these guidelines:
Always load the short edge first, even when you’re printing landscape-oriented pictures.
When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package.
Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
SOURCE: My printer Epson Stylus PHOTO R230 does not print
The printer does not print only dragging a paper without printing.
3 option to solve
make sure your
1. heads are working
2. flex cable connecting the heads
3. main board
Most common that i found is to replaced the main board. or replace parts of other main board if you have some extra. hope it can help.
