SOURCE: My GPS started smoking and quit working. After 2
If there's smoke, there's electrical problems. Chances are it's gone.
SOURCE: heater only works a few
These may be due to a few thing but first you will need to test when blower is out, using a testlight check blower plug for power and ground, if theres power and a good ground then you have a bad motor if theres no ground to blower then the resistor is bad, also make sure the plug to blower or resistor is not melted or brunt. good luck the most common problem is the blower or resistor.
