SOURCE: willnotrecoil
Hello . First thing is remove the starter rope and check to see if the flywheel turn by hand . If turn by hand you have a bad recoil starter , if does not turn by hand the piston is seized . Remove the spark plug and put 2 or 3 drops of oil (2stroke mixing oil) on the spark plug hole and try to turn it again by hand . If still does not turn you have to replace the piston and maybe the cylinder .
Hope this help
SOURCE: need gasline size
The best way to get the correct size lines is to take a piece of the old lines to your local outdoor power & equipment store, or sometimes your local auto parts store will carry them, and let them match them up. You may have two different size lines, so make sure to get pieces of both.
Jim
SOURCE: Need to know specifications of spark plug for Ryobi Leaf Blower
You can download the manual at www.managemyhome.com. I have the Ryobi 720r and the sparkplug is a champion RDJ7Y.
SOURCE: I have a 25cc weedeater leaf blower that will not
Order a new fuel filter and fit it on the existing line...unless the line is brittle and breaks easy in which case you would replace the line. The fuel lines pass through the tank and are fairly easy to replace plus they ahve the added advantage of being cheaper than a new fuel tank.
SOURCE: i need a manual for a 25cc 2 cycle featherlite
try going on the internet to
poulan.com/manual, can d/l a manual from there
