SOURCE: No dip switch in Hunter 27157 remote control.
Those aren't transistors in the transmitter they are jumpers. Match the jumper settings with your dip switch settings in the receiver. You can move the jumpers in the transmitter using a small needle nose pliers. An open jumper in the transmitter equals an OFF setting on the dip switch in the receiver.
SOURCE: I have a hunter remote
There is no way. Only the manufacturer can reconfigure thw remote. That is part of the defect of this product.
If it works fine, leave it and just continue to use it.
Cheers.
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
SOURCE: Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
SOURCE: The light on my hunter ceiling fan flashes on and
remove watt governor for lights. ( little black box). and wire lights direct. this is your problem.watt governors are used to reduce light output or energy. just remove it.
