Hi:
I installed the drivers for the HP Officejet 6210 All-in-One, however, when I hit scan on the printer I get an error message that reads "No Scan Options. You need to install or run device software for feature." can you help.
Vista?
Pressing of scan button feature is no longer supported by hp drivers, if installed correctly one scans using scanners and fax
When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly.
Solution
Scan documents using Windows Fax and Scanning or Paint.
Scanning with Windows Fax and Scanning
Scanning with Paint
Cause
The drivers in the Windows Vista operating system do not support button press functionality on the printer.
link to above info from HP
Haha! paint actually worked perfectly.
thanks so much for this quick fix!
SOURCE: HP officejet 6210-unable to run scan feature
pls folow this link step by step to get the resolution
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00503569
Thanks...worked like a charm.
i have the same hp officejet 6210 and when i hit scan i get a message "no scan options" ?? what do i do??? help please
Yes, I have the same problem with my 6210. Hit the scan button, the LCD says No Scan Option install or run software device.
I get the same message and I have gone to he website and tried every download! Nothing has helped and I sill can't scan anything.
