Question about Toro Garden
Toro model - 51599 serial # 310052153 Looking to repair damaged bushing on electric motor and replace 2 moto brushes. I cannot find a part # for these items. Can you provide? Thank you.
    Top Expert:
  • Toro Master
  • 55,370 Answers
Contact Toro directly to inquire.
Posted on Sep 12, 2019
Anonymous
SOURCE:
reddevil6
Lauren Junge
  • 1673 Answers
SOURCE: brush motor failure
Looking at the parts breakdown, the motor must be in the nozzle asm. part # 75213 and sells for about $25.
Posted on Jan 15, 2008
vincob
vince janis
  • 718 Answers
SOURCE: Looking for a service manual to repair Toro Super Recycler GTS5
Try jacks small engines online!
Posted on Nov 25, 2009
usavacuum
  • 57 Answers
SOURCE: Hoover Savvy U8174-900, replacement circuit board LED/Brush Motor
clear1x1.gif Hoover Switch & Circuit Board with Handle for Hoover Savy & Bagless
Follow this link to USAVACUUM.COM
www.usavacuum.com/category-s/63.htm
Posted on Feb 21, 2010
eb78
SOURCE: My toro model 51599 ultra with metal impeller
If you take it apart there is a little spring on the bottom of the motor. When overheated it "trips" and looses contact with a wire. Need to reset the spring.
Posted on Mar 24, 2011
Brad samm
SOURCE: toro 51591 and torro 51599 will not start
The blower has a cover that snaps on to the tube and covers the propeller. I always use blow mode and it stopped working. I thought the motor was dead but flipped the cover to be in suck mode and it worked. I then put a layer of duck tape around the full circle of the blower side and it snapped in and works fine.
Posted on Jun 13, 2013
Why will my toro 5198 leaf blower not start?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jun 28, 2014 | Toro 51599 Electric Blower 12 Amp
Where can i get a replacement motor for a toro model 51599 blower
Toro motors are not available a reasonable price. If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may still be able to use your motor by replacing the carbon brushes and or cleaning the commutator. Hope this helps.
May 12, 2014 | Toro 51599 Electric Blower 12 Amp
Motor won't turn on
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Apr 14, 2014 | Toro 51599 Electric Blower 12 Amp
Blower does not turn on
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Apr 03, 2014 | Toro Garden
Snow blower shorted out
Feb 17, 2014 | Toro 51599 Electric Blower 12 Amp
Motor was losing power and burning
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
Problem is my hardly used Toro Blower Vac is getting no Power
If it has not run for awhile, check the brushes. they might need to be replaced. The plug is usually moulded right on power cord. That might have to be replaced because if there is a problem with a broken or disconnected wire right at plug there is no way to see it. Hope this helps.
Dec 07, 2010 | Toro 51599 Electric Blower 12 Amp
Plugged it in and it won't run but it was running fine when I put it away two weeks ago.
Check the plug for loose wire or at blower where wire it enters to make sure the wire was not pulled and disconnected inside. If after looking and it is not a wire, check the brushes on the motor. They could be worn out or not making a good contact. Blow out brush housing and re-install brush sometimes this works. That's about all I can think of unless there is a safety switch then check that. Good luck.
Nov 22, 2010 | Toro Craftsman 225 mph Electric BlowerVac
Motor on mod 51591 died, nedd replacement
The Mamco motor is WAY too much money.I bought brushes on E Bay and made them fit. #51591 takes 1/4 " square brushes.
Nov 28, 2009 | Toro Blowers Rake and Vac - Electric...
After a couple of hours of use last week, the motor started slowing down. Turned it off and it would not restart. tried again after an hour and it started but sounded really rough. stopped it and took it...
sounds like the motor is worn out. Toro does not sell the motor separate. It is considered a throw away unit.
You will have to purchase a new one.
Sorry.
Good Day.
Nov 05, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
Garden Logo
64 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
roeb
Marvin
Marvin
Are you a Toro Garden Expert? Answer questions, earn points and help others
