Use the matching connector. Reset the device
Hi Andrew, what kind of speakers do you use?
If they are passive, they will not work, because your icf-sw55
It has headphone output and recording output
You must use powered speakers or connect it to an audio amplifier
Discuss what speakers you are using
Regards Franco Dosil
Hola Andrew, que tipo de altavoces utilizas?
Si son pasivos, no funcionaran, porque tu icf-sw55
tiene salida de auriculares y salida de grabaci?n
Debes usar parlantes potenciados o conectarlo a un amplificador de audio
Comenta que parlantes estas usando
Saludos Franco Dosil
https://www.manualslib.com/products/Sony-Icf-Sw55-2954809.html
https://www.manualslib.com/manual/991971/Sony-Icf-Sw55.html
SOURCE: Sony ICF SW55 always OFF
I have the same radio.
It was given to me not working
I took it apart.
Was surprised about the contacts not being soldered
After re assembly and with new AA nicads it started.
First it would take clock and then go off
losing clock settings.
then it comes on and starts fro factory CAL menu.
after repeating many times now coming on with all functions
volume not great
sensitivity/signal strength good
Now after recharging batteries stays on and last longer.
It appears that resistance/poor contact with circuit board of battery connections causes l;oss of voltage.
Suggest follow these steps cleaning with solution and may be also re tensioning contact contact areas.
jmho
good luck
