Question about Stihl Garden
I have a stihl chain saw there's switch on the side by the cluch what's that for a 0 44 so what it is
6ya staff
SOURCE:
stug_57u
Stuart
  • 99 Answers
SOURCE: cant find serial number on stihl chain saw ms 290
If the silver rating label is still on the safety brake lever, it should be on there. If not, look at teh housing to the left of the exhaust by the 'teeth' on the body, or on the housing below the exhaust. It is normally stamped into the plastic.
Posted on Oct 26, 2008
Savu Mihai
  • 211 Answers
SOURCE: Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
Posted on Feb 14, 2009
Anonymous
  • 148 Answers
SOURCE: parts breakout for stihl 041 (farmboss) chain saw
Stihl has terminated almost ALL support for this model and Illustrated Parts Lookups are not available online for Stihl products.
Posted on Oct 05, 2009
dontbother10
dontbother10
  • 2220 Answers
SOURCE: owners manual for a Stihl 034 AV Chain saw
Stihl Manuals
http://www.stihlusa.com/information/info_product2.html
For an IPL you must contact them.
HTH
Lou
Posted on Oct 19, 2009
dontbother10
dontbother10
  • 2220 Answers
SOURCE: cant find serial numbers on stihl chain saws
For some the serial number location in the Product Instruction Manual here:
Stihl Product Instruction Manuals
If yours is not please contact Stihl here:
Contact Us
http://www.stihlusa.com/contact.php
HTH
Lou
Posted on Jan 15, 2010
Where to get points for 016 stihl chainsaw?
Stihl Chainsaw Parts ' Chainsaw Parts ' Discount Online Parts
https://www.discountonlineparts.com/chainsaws/?b=stihl
  1. Cached
  2. Similar
Quality Stihl replacement parts, cheap and quality available online.Handlebars and Housings · ‎Bar/Chain Combos · ‎Stihl 041 Cylinder Assembly ...
Stihl Chainsaw Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a30b354/Stihl-Chainsaw-Parts
  1. Cached
Stihl Chainsaw Parts - Shop online or call 800-269-2609. Fast shipping. Open 7 days a week. 365 day return policy.
Chainsaws ' Parts, Accessories, Reviews & Pricing ' STIHL USA
https://www.stihlusa.com/products/chain-saws/
  1. Cached
Choose from the wide selection of reliable, dependable and high performing STIHL chainsaws with low-emission technologies and quieter, more fuel-efficient ...Homeowner Saws · ‎Professional Saws · ‎Farm & Ranch Saws · ‎In-Tree Saws
Stihl Chainsaw Parts ' eBay
www.ebay.com/bhp/stihl-chainsaw-parts
  1. Cached
  2. Similar
Find great deals on eBay for Stihl Chainsaw Parts in Garden Chainsaws. Shop with confidence.
Home ' STIHL
en.stihl.ca/index.aspx
  1. Cached
  2. Similar
STIHL - Information about the STIHL Group and our extensive range of chain saws and ... About us More than the world's most successful chain saw brand. stihl chainsaw Google Search
Nov 23, 2016 | Stihl Garden
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Is the LA adjuster for oiler to chain& what 1/4 turn per run to check ratio??
PDF]STIHL MS 261/261 C Chain Saw Instruction Manual ' STIHL ...
www.stihlusa.com/.../ms-261-261c-chain-saw-instruction-manual.pd...
Stihlde la rueda dentada usada y de otros ... this manual to operate your chain saw. ..... 1/4 turn). Misaligned, damaged or broken cap. N. If the cap does not drop fully .... adjust the chain while the engine is running! Warning! To reduce the risk of fire ...... bolts and screws except the carburetor adjustment screws after each use.
[PDF]STIHL MS 200 T Arborist Chain Saw Instruction Manual ...
Dec 15, 2015 | Stihl Garden
What Stihl chain should actually go with this bar?
3003 001 6113
3003 Is for the 048
001 (internal Logistic number)
6113 the last indicates bar length which you already know as 25"
It for 3/8" chain.
All need to know is its gauge which can determined from the your chain's drive links number.
1 .043" 1.1 mm
3 .050" 1.3 mm
5 .058" 1.5 mm
6 .063" 1.6 mm
0 .080" 2.0 mm
Jan 17, 2015 | Stihl Garden
Where is the decompression switch on a 075 stihl chain saw ?
If your unit is equipped with a decompression or it will be on the top of your saw. a little black button that you pull up or push down
Oct 15, 2014 | Stihl Chain Saw 051 075 088 090 +
I can't tighten the chain on my stihl ms 251 chain saw
Pull the side cover and check for a broken or misaligned chain tensioner. I assume that you have loosened the bar nut on the side cover before attempting to adjust the chain tension. The methiod varies depending on whether your model has the side chain tensioner or the quick chain tensioner.
Dec 08, 2013 | Stihl 029 039 Ms 290 310 390 Chain...
File size sharpening stihl 023C
There are six different chains with different pitches that can be used on this saw. 1/4, 3/8 PMN, and 3/8 P use a 5/32" file; 0.325 uses a 3/16" file; 3/8 uses a 13/64" file; and 0.404 chain uses a 7/32 file. The pitch is ususally stamped on the side of the chain teeth.
Sep 25, 2013 | Stihl Chain Saws, 017, 019, 021, 023 & 025
Too much oil is being delivered on the chain, how do I adjust the oiler on my Stihl 038av super?
This is Stihl's manual showing the proper adjustment for the oiler. Flip the saw on its side, chain and bar side up, and look for a flat head screw.
Clockwise rotation on any saw is more oil, and counterclockwise will be less oil.
Nov 25, 2010 | Garden
Garden Logo
54 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Joe Paxton
Level 1 Expert
ray gallant
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
