I have very little experience of internet connected vehicles but when my friend took delivery of his new car, the dealer guy asked him whether he wanted his phone connected to it and when he said yes the guy fiddled around for a bit then asked for his number and entered it into the car computer.
If something can be switched on it surely can be switched off, though it would probably be best to entrust it to the dealer.
SOURCE: Text Messages
The text messaging is the functionality of the netwrok not the handset. Unless Verizon offer this service phone is not going to have that option. (Just like block numbers, etc.)You can call Verizon and see if they have some solutions since you are not going to be the only one with this problem.
SOURCE: Update contacts new phone number
Update w/ new number: Go to Address Book, begin typing name, scroll to contact and select, with contact showing press the Blackberry button and choose "Edit".
Backlighting adjustment: Options>>Screen/Keyboard>> adjust the brightness setting (listed in % 10-100). Then press the back button and Save your settings when prompted
Short call history available by pressing the green phone key.
SOURCE: message comes up PHONE START UP FAILED. CONTACT
This is usually caused by corruption of the phones firmware. You will need to take the phone to a reputable mobile phone engineer or Nokia Service Point for repair.
SOURCE: 1) Everytime I turn the
Well, it looks like you haven't selected the correct WAP settings. How many service providers' settings have you saved on your phone? In most cases, "whatsapp" application causes this problem, the only solution is to uninstall the "whatsapp" application (as far as I know) otherwise you'll be notified everytime your phone is turned On. But in many case, if your network is AAPT (or other specific network/s), then accepting the warning and setting up the access point automatically should also fix your problem. But if you have several network access, that would be different, suppose if you keep changing your sim card, you'll need to change the settings every time you switch your sim card.
You can also try this method, go to settings > connectivity > destinations > and then (by one depending on how many acces points you have on your phone), choose any access point, then press options and go to advanced settings and then change the network type from IPV4 To IPv6, and save the settings, repeat the steps with all the network access point you don't use.
Hope this helps.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
SOURCE: my alcatel e100 t mobile
Your cell phone may be locked to a particular cell phoneprovider and in this case it needs to be unlocked to use with a different cellphone service provider. To get the security code/restriction code to unlock thecell phone from the current cell phone provider so you can use the SIM cardwith a different phone provider, Please click on this link and follow myinstructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then these WEBsites it provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw http://www.mobileunlocksolutions.com/ Try this WEB sites - http://www.superunlockcodes.com/unlock-your-phone/rs12wp2/ http://www.unlock-free.com http://www.unlock-zone.com/ http://www.unlocking.com/
