Question about ASUS Computers & Internet
MY ASUS 1225B HAS HAD THE HARD DRIVE WIPED IN AN EFFORT TO INSTALL WIN 10. BUT I CANT INSTALL WINDOWS 10. HOW DO I RE-INSTALL A OPERATING SYSTEM ON THIS MACHINE. THE RECOVERY PARTITION WIPED TOO...
MY WINDOWS 10 INSTALLATION IS ON A USB STICK AND THE LAPTOP ALSO HAD MX LINUX INSTALLED.
  • 409 Answers
The hard drive needs to be formatted and you need to have the boot order set to the 1 usb 2 hard drive in the bios.Also make sure your installation files on the USB aren't corrupt.The USB needs to be formatted before the installation files are loaded on to it.Make sure your laptop is Windows 10 capable.I think it should be loaded with Windows 7 first then maybe upgraded to Windows 10.Here is a link for tools you may need to get Windows 7 on the laptop after having Linux installed......(https://www.asus.com/Laptops/Eee_PC_1225B/HelpDesk_Download/).....Hope this helps
Posted on Sep 13, 2019
6ya staff
SOURCE:
Anonymous
  • 31 Answers
SOURCE: problem with e-recovery 10 gb hided partition, how to restart explotation system
reformat your hdd
Posted on Mar 11, 2008
iqbal_del
Iqbal Husain
  • 655 Answers
SOURCE: SEAGATE HARD DISK DRIVE PROBLEM...
grt seagate nice brand...
whenever yor OS is currepted this type of messages raised. its not only due to bad hard drive. I think your hard disk is ok. If you want to make a check you can run scan disk to see if you have any bad-secter on your HDD, if you have then its HDD problem, otherwise its ok.
Thanks
Iqbal
Posted on Apr 01, 2008
bozape
BOZAPE
  • 44 Answers
SOURCE: Problem installing Windows XP with Asus P5RD1-VM series mothboard
Hi!
You need to copy the SATA drivers from the motherboard CD into a floppy diskette.
When you are booting with the windows xp installation CD you can see a message that says:
Press F6 for raid drivers
Press that key so windows installation CD look for the SATA drivers.
Posted on Jan 20, 2009
jepito
Kevin Groce
  • 216 Answers
SOURCE: Aspire 5315 down and out new hard drive, bunch of problems
and home or pro xp will work you should have thexp cd key code on the bottom of the notebook - go to acer .com to download the drivers ..... i can make you a cd for 20 bucks if so email me @ jepito@gmail.com and ship it to you in 3 days the sticker on your pc will tell you what it was xp home xp pro or vista :()
Posted on Sep 10, 2009
Anonymous
  • 74 Answers
SOURCE: asus p5kpl-am in USB and Sound not detectiing
try to make an adjustment on your bios i think usb is disable try to enable it and sure all your usb will work.
Posted on Oct 14, 2009
How to uninstall windows 10 and install windows 7
win 10 is an os so you may need to reformat the hard drive to get it out
you will need a disc to reboot the computer and instal win 7
If you are not real sure on how to do it , first save everything you have on an external hard drive/gig stick as reformatting the hard drive deletes everything or have a computer technician do it for you
As a side note, I have been playing with the idea of upgrading to win 10 from win 7 but was hesitant to do so because of all win 10 problems appearing on this page and in a conversation with a computer technician and programmer he explained that all the problems come from the up grade process-- something like a conflict appears between the two operating systems trying to operate on the same base codes
He said that if the win 7 was removed and win 10 installed complete from the disc there are no conflict problems and the operating system works well
I suspect that you are having problems with the win 10 after the upgrade and not from a full installation so it may be worth your while to speak with a tech expert to get good advice before you run the risk of loosing all data
Jan 19, 2016 | Computers & Internet
I need to reinstall win 7 and wipe my system
Put Windows 7 disc in the drive and boot from it. Windows 7 install will start. Follow the steps, it's easy and you have done it before.
You may have to change boot order from BIOS to get it boot from dvd.
How to Install Windows 7 Beginners
Jun 04, 2015 | Microsoft Windows 7 Home Premium 64BIT...
I have an Asus Eee pc R101D netbook, Cant get it to fully boot up, operating system is Windows 7 Starter, I have no Re-installation Disc, Also cant get my external Disc drive to work from the USB slot, I...
your operating system is located on the hard drive if you still have the old one and it works put it back in make a back up copy on cd remove and reinstall new on and load operating system to new hard drive.
Mar 11, 2015 | ASUS Computers & Internet
Asus 1225b slow boot win 7
Most likely Yes. Her are some tips: http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332 Use freeware CCLEANER: http://www.filehippo.com/download_ccleaner/ This freeware program has many useful tools. The cleaner will remove junk and free up disk space. In the TOOLS section, STARTUP section, disable ALL unnecessary startup programs. Remember, almost every program you install wants to startup at boot, which, in most cases isn't necessary. You can configure what you need at start, use CCLEANER, TOOLS, STARTUP.
Mar 26, 2013 | ASUSTeK COMPUTER ASUS Eee PC 1225B - E-450...
"asus" laptop boot from bios
Hi.
If you are trying to install Windows 7 from the USB flash drive then you need to configure the drive so the system will see it as a boot drive, see link below for instructions on how to do this. If you have Windows 7 installed on the flash drive then the boot files may have become corrupt thus preventing you from booting into the operating system. Link for installing Win 7 from USB below >>>>>
http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
Regards.
Feb 04, 2013 | ASUS Computers & Internet
HDD not detect with win xp instalations. Cannot downgrade to win xp. somebody help. im not litterate with windows 7
Before you downgrade operating system you should enter bios setup.
turn on >>> press DEL key repeatedly
On Hard drive section >>>change AHCI to IDE >>> save and exit
you can start install win xp.
Note : to upgrade to win 7 do reverse
akee.4shared.com
Aug 15, 2011 | ASUS Eee PC 1215NPU17BK Netbook
Can you please help me how to fix the BIOS ROM CHECKSUM ERROR. TO MY MOTHERBOARD (TRINITY 400 S1854 AGPX4-PCI-ISA) i reformat the windows NT version 4, and after i restart, the message come bios rom...
turn the computer off
now turn on and hold down the delete key until the bios screen appears
in the boot tab select first boot as the cd disk, install the cd for win nt in that drive
close down the cd and then restart and it will boot from the cd
BY reformatting the hard drive win nt you have wiped the win nt operating system from the hard drive
Feb 17, 2018 | Tyan Trinity 400 S1854 Motherboard
Wiped clean hard drive now the windows xp home won't let me install
Hi ADIDJAN,
If you have the original installation cd than you can re-install your original operating system then upgrade it with xp afterwards.
Hope this helps and good luck
Jul 27, 2008 | HP Compaq 6510b Notebook PC
Win vista uninstall
Put your window XP disk into the Disk drive. Start up your computer. When it asks you what Drive you want to install it on select C:\ (where Vista is) Say yes to deleting the current Operating System and follow the instructions from there.
You did say you wanted to Uninstall Vista!
If you mean Dual Boot Vista and XP, then you will need to create a Logical Partition of about 10 Gb to install XP on and when asked where to install select this partition. But note that XP will wipe the Boot sector clean of all other Operating Systems which means that if you want to Dual boot then you will have to reinstall Vista again to get Dual Boot functionality.
Apr 14, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
