Tablets & eReaders Logo
s
sharleen Posted on Sep 13, 2019
My apple ipad is asking for an itunes password. what should i do
Brian Acker
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Sep 18, 2019
Brian Acker
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
0
Helped
1686
Points
25
Go to lost password in itunes have then send you a recovery email. If you just bought the tablet second hand then you may need a factory reset. If you do not have an apple i tunes account you will need to set one up as well.
5 Related Answers
Gil Shultz
  • 3464 Answers
  • Posted on Dec 19, 2014
SOURCE: I have two Apple ID's on my iPad. How do I get rid of one if I don know the password or security questions?
Your best source of help would be to call Apple. They go out of the way to support there products.
Rick kearney
  • 13 Answers
  • Posted on Jan 08, 2015
SOURCE: how do i factory reset apple ipad i forgot my apple id and password
Resetting the ipad will not help... The I'd and password are stored at the apple store.
ineedabin50249
Joe Stanch
  • 755 Answers
  • Posted on Jan 10, 2015
SOURCE: i have an ipad that ask me for apple id that was used to erase this ipad.how do i get pass this
you do not , it is locked to icloud and the real owner is the only one that can open it , look on youtube you will see what I mean
Jude24
  • 313 Answers
  • Posted on Nov 14, 2016
SOURCE: I have an apple iPad I disabled my iPad because I forgot my password , I try too many times , it is letting me know to connect to iTunes , i not understanding why . Thank you .
All of the Ipad interface is done through i-tunes. You have to connect there to do the setup or retrieve your setup. It doesn't seem to make sense, but that is the way Apple does it.
johnnydie49484
johnny diesel
  • 10 Answers
  • Posted on May 19, 2018
SOURCE: how to set up password on my new ipad mini
Follow these Tips:
1. Firstly, Swipe right on your iPad's screen to unlock it.
2. Now, open your "Settings" app on iPad.
3. Scroll until you find the "Passcode" option, then tap it.
4. Tap the button "Turn Passcode On".
5. Enter a passcode of your choice.
6. Confirm your passcode by typing it in again button.
7. Press your lock button to lock your iPad device.
Read more at Set A Passcode On The IPador Call 1-800-608-5461 iPad Support Number
Why does my IPad always ask for the ITunes and IPad password but will not accept it. Also it shows "a problem has repeatedly occurred on Apple ID
The password is incorrect. Remember these password need to be exact, capitalization is usually the culprit.
Next, you Apple ID may be different from the iTunes password.
You should be able to recover either through Apple support.
Apple ID and password help. My deceased husband set up the password and ID and I am locked out of my IPad. It asked for the original
Try hooking your iPad up to iTunes on your computer and perform a factory reset, changing the username and password.
My sister forgot her Apple ID on her iPad and she's 55 and can't remember her password what to do?
Under this circumstance you may have to reset the iPad if you forget both Apple ID and its password.
To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your tablet. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
1helpful
2answers
I can't unlock my Ipad, it won't accept my password, how can i change my password
If you have synced your iPad with iTunes before you forget your password, you can reset your iPad by using iTunes without losing data. Through iTunes, you can restore your iPad from the last backup and remove the passcode from your locked tablet while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPad Passcode with Recovery Mode section below.
Step 1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
Step 2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPad without any passcode. And you can set your new password on iPad.
http://www.leawo.org/tutorial/how-to-reset-password-on-iphone.html
How can i get passcode
Hi Donald. Do you forget the passcode?
If you have synced your iPad with iTunes before you forget your iPad password, you can reset your iPad by using iTunes without losing data. Through iTunes, you can restore your iPad from the last backup and remove the passcode from your locked iPad while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPad Passcode with Recovery Mode section below. The following steps will show you how to reset iPad password with iTunes.
  4. In the Summary window, you can see the option "Restore iPad". Click it and follow prompts to choose the latest iTunes backup to restore your iPad.
How to Reset Password on iPhone
Don't remember password for ipad
You don't need to know your password for the iPad. As long as you know the password for your iTunes account, you used to setup the account on the iPad for. Connect the iPad with the computer and open iTunes and give in the password for the iTunes account. Apple will unlock the iPad and you can setup a new pass code for the iPad.
When you forgot your iTunes password, you have to contact Apple and prove you are the legal owner of the account.
Use this link to find more support for that:
Apple ID Support
My ipad is locked how can i fix it
You have setup an iTunes account with Apple. When you connect the iPad to iTunes, (WiFi or via computer) they ask you the password for your iTunes account. If you forgot that one, Apple can send you an reset code to the mail address connected to the Apple account. (Not the iCloud mail)
If nothing works, goto the closest Apple store and take your invoice with you and an ID card, to prove you are the legal owner, perhaps they can help you.
2helpful
4answers
How do i unlock my ipad i bought it used and i dont have a password and now it is locked and asking for password
You will have to restore it by connecting to iTunes on your computer. That will erase all settings including the password. If you have a backup you can get it then set up as a new device with a new password.
How do I unlock a disabled ipad 2?
First try to reset the iPad, by pressing both the home button and the on / off button, till the apple logo comes on the screen. Then try again. You should have a password for you Apple account, because that will be asked. If you don't have an account name for the device not worth trying, because it will be blocked anyway.
If this does not work, why not try one in this link?
How to Reset Forgotten Password for an iOS Device
2answers
How to unlock an Ipad after forgetting the pass code
Have you ever synced your iPad in iTunes? If this is the situation, there are many postings on Apple and other sites to restore your iPad and password.
If you have never synced your iPad in iTunes, you will have to take it to an Apple Store or send it to Apple to be restored...
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
