SOURCE: I bought a Callaway CY2130
at the sides of the stainless steel bracelet near the lock you will see holes its a small screw, use a small screw for this. just be careful with your hand.
SOURCE: I have a UPROGO Callaway
Hello
You are mentioning about the "scan and fix" facility of your uPro Go device I thinks. Windows Vista users may be given this option. If you are using Vista, inform me by Fixya. OK.
SOURCE: Callaway upro had been working
I've had my uPro for a couple of years and everyonce in a while it gives me a few problems. It has always been solfved for me by removing the battery and letting it sit for a while, an hour or two will do, and put it back in.
The sad part though is that if, it does not work for you. Because it only means that you need to update the firmware of this device and the website for Cally where you're supposed to do the download is not so user-friendly. Why? It will fail and ask you to contact them by phone on Mon-Fri 6 a.m. - 5 p.m. (Pacific) at 800-588-9836 or 760-931-1771.
Thank you for choosing FixYa!
The Device is equipped with a no. of features however if you are stuck due to blank screen issues. You can try to reset it once. This will bring your device to the default factory setting and you can use it properly after that. To learn the easy easy reset your device you can browse the attached links:
http://gpsupdatesupport.com
http://magellangpsupdates.com
http://tomtommapupdate.com
http://garminnuviupdates.com
