Question about Simpson Washing Machines
Hi my Simpson 9.5 kg over flows even on the low setting What is the problem I have swapped the inlet valve as I only use cold water.
    Top Expert:
  • Simpson Master
  • 30,787 Answers
Unblock the water level sensor on the rear of the drum.
Posted on Sep 14, 2019
6ya staff
SOURCE:
douglas smith
  • 1462 Answers
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Posted on Jun 22, 2007
Anonymous
SOURCE: HITACHI WASHER SF 6500PX, COLD
hitachi washer sf 6500px lid for washer
Posted on Mar 07, 2008
rpbuice
Ron Buice
  • 161 Answers
SOURCE: Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Posted on Jan 08, 2009
SOURCE: Fisher/Paykel GWL10US washer. Blinking hot and
When they say replace the valve There,s a very good chance the diaphram is the valve is purferated or split (common Problem).But you can Remove the coil from this & with pointy nose plyers you can unscrew the top & inspect the diaphram If it,s ok give us a bit more info Hope this helps.Cheers.
Posted on Aug 10, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Hoover 2307L 7.5 cold water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Jul 12, 2011
Setting our machine on warm , but the water s hot , both hot & cold taps are fully turned on .
Check your hot/cold inlet valve and solenoid. It sounds like your cold water side of the valve is stuck shut. The valve is found by following the inlet hose right to it. Also, do you have a domestic well as water supply? Sometimes fine sand from a domestic well will plug the valve screen. It is also possible that other mineral would plug the screen. These things would happen gradually, though, not all at once.
Feb 02, 2017 | Simpson Washing Machines
My Simpson ezi sett 7.5 always fills to full even when set to low. i have replaced the pressure switch and still fills to full.
Check the rubber hose from the pressure switch down to the bowl for any holes or splits allowing the air pressure to escape. Also check that water valve is stopping the flow. Start to fill then press pause. Water flow should stop immediately. If it keeps flowing or is slow to stop then replace the inlet valve. Try it several times to be sure.
Dec 18, 2016 | Simpson Washing Machines
Cold water isn't coming on, only hot?
Not sure what ur saying have u tried changing the hot cold hoses and see what happens? u may have a bad water inlet valve or a bad water temperature switch? first make sure ur getting hot from the house outlet, u can check with a multi meter for continuity to see if either is out
Mar 15, 2015 | Admiral AW22 Top Load Washer
Asko front loader fills with water when switched off and once turned on will immediately sense it and drain it from the machine. What could be the problem? The machine still washes beautifully, even after...
inlet valves are out of service or malfunctionnign follow the steps .
1. unplug your machine power cord.
2. open the door and also open water supply , if your machine fills the water then 100 % problem is with your inlet valves , replace it , simple
regards
Dec 31, 2014 | Asko W6021 Front Load Washer
I have a Simpson Espirit 6.5 kg front loader. Model 45 S 651 D. The washer takes a long time to fill with water and the soap container is not washing out. I believe it might be the Cold Water Inlet...
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 01, 2011 | Washing Machines
Hot water fills very slow(30 MIN OR MORE TO FILL) good water flow from spicket to washer, screens are clear. sewems to be something with the washer its self
Might be a bad inlet valve. To confirm, swap the hot and cold hoses to your washer so that the cold water feeds the hot water connection and the hot water feeds the cold water connection. Turn off both hot and cold water faucets. Set the washer for a warm water wash. Turn on the cold water faucet, and check the flow. Then turn off the cold water faucet, and turn on the hot water faucet and check the flow. If the cold water flow fill slowly, then the problem is with the inlet valve.
It an easy part to obtain from an appliance supply house. To install disconnect the hoses to the back of the machine, and remove the back panel to get access to the valve. Should only take a couple of minutes to remove and install. Hope this helps you.
Oct 26, 2010 | Kenmore 24032\24036 Top Load Washer
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
F&P Intuitive eco (IW811)
Even though the resistance of the valve is normal, doesn't mean that it cannot be faulty. Try swapping the valves around and see if you still get cold water coming in through that valve. If not, then the valve is faulty. Don't forget to put the cold valve back where it belongs. There is a difference between the hot and cold valves( cold valve is a proportional valve) but for testing purposes they can be swapped around. To set the size you have to switch the machine off at the wall. Switch it back on again. Wait for all led's to go out. Press & hold the start/pause button while you push the power button. Switch off again and it should be o.k.
Apr 01, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
Top Simpson Washing Machines Experts
STEVE
j_woodman
Level 1 Expert
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
