Since this set like all others with the "child lock" require a code to be entered and the remote is what is used, I would say it cannot be done without the correct remote and the password.
Hi what you can do is to buy a universal remote control for this TV to remove the child lock. You can get that online or on any electronic shops in your area. Once done here is the instructions on how to remove the child lock using remote.
Look at the "Power" indicator light on the front of the television to check if it is blinking. When blinking, the child lock is enabled. You can also check by pressing the "Power" button on the television.
Point the remote control at the television and press one of the buttons on the number keypad. The "Power" indicator light will stop blinking, indicating the child lock is turned off.
Lock the television again by pressing and holding the "Power" button on the remote control until the indicator light starts blinking. It takes approximately three seconds before the light turns on. Thanks
i had same problem with telefunken ttv2931 child lock, tried turning off power,holding power button on and pressing each button, found by accident that holding down the display button for 5 to 10 seconds worked.
can't remember code...Want all stations
i HAVE SEAM PROBLEME
