Question about Crl Automotive Vehicle Parts & Accessories
94 Ford E150 door lock wiring - Crl Automotive Vehicle Parts & Accessories
3 Suggested Answers
6ya staff
SOURCE:
Jimmy James
  • 260 Answers
SOURCE: Need instructions on how to remove the door
Look for the phlips head screws in arm pad area and around panel. Once removed you can pry off panel but be carefull not to break plastic clips if you do no sweat they are cheap to replace.
Posted on Apr 09, 2009
VICTOR QUEZADA
  • 151 Answers
SOURCE: My 94 e150 Ford van is still sputtering adle and
TRY FUEL FILTER IF NOT THEN DISCONECT YOUR EGR VALVE TEST DRIVE SEE IT GOES AWAY OTHERE DO A FUEL PRESSURE TEST AND CLEAN YOUR MASS AIR FLOW SENSOR IS CHECK ENGINE LIGHT ON LET ME KNOW IF IT IS GO TO AUTO ZONE AND GET CODES IF LIGHT IS ON LET ME KNOW WHAT CODES ARE ON IT OK
Posted on Nov 14, 2012
Cant find the plug for the control actuator on a Ford E150. Door is not switching so only cold air is blowing.
What year E150 ? Manual or automatic HVAC ? What door isn't switching ? Mode door , temp. door ? Some ford's have a valve under the hood hooked to heater hoses called hot water valve , allow hot coolant to go through the heater core . Ford Explorer 1992 heater control valve install Explorer E150 doesn't matter ford used on all there vehicles ! Some are vacuum controlled others are controlled by a cable !
Sep 29, 2016 | Ford Cars & Trucks
How do I disable electric door locks on 94 Crown Vic
open door find which wire going to powerr lock cut it or take door panel off reach in and unplug plug on power lock motor
Sep 06, 2012 | Ford Crown Victoria Cars & Trucks
Wiring diagram for rear door lock/handle
with or without memory locks can email you a diagram ,e mail me @ derekneilsen1@gmail.com give me year and engine size and is it a e150,e250 ext.
Feb 25, 2011 | 1994 Ford Econoline
The power locks will not lock at all but will unlock sometimes ford e150 year 1999
The door lock actuators are faulty from old age . They need replaced and run about $40.00 each. The master switch may be faulty also but you can not tell untill you put at least one new actuator in and try it.
Nov 20, 2010 | Ford E-150 Cars & Trucks
94 e150 no remote can't get starter to unlock help
Remove plug from alarm, remove starter motor and clean bendix with wd40, replace and she will start
Jun 28, 2010 | Code-Alarm Code Alarm Transponder
Need detailed diagram of 1998 latch mechanism to remove connections from it
there is no diagram... the latch is also a non-servicable latch, so if your problems in the latch- it needs a latch. i would look more closely at the outside door handle itself as i have seen a few of them break on the E series vans.you may be able to get detailed instructions thru autozone.com or @ autozone. hope this helps and good luck
May 28, 2009 | 2003 Ford E150
Need instructions on how to remove the door interior panel on a ford e150 to service/replace the door lock solenoid. The door lock intermittently fails to respond.
Apr 09, 2009 | 2003 Ford E150
1999 Econoline E150 Van mirror replacement
Remove the door handle bezel.Remove the power window/door lock switch bezel.Remove the rearview mirror fastener trim cover.Remove the 4 door trim panel retaining screws.One that was behind the mirror trim cover,behind the switch panel,behind the door handle bezel,and one at the bottom corner.Lift the door trim panel up from the door to disengage the trim panel clips.Remove the front radio speaker. Disconnect the power mirror wiring connector.Remove the 3 bolts to the mirror.
Feb 08, 2009 | Ford E-150 Cars & Trucks
Vehicle Parts & Accessories Logo
53 people viewed this question
Top Crl Automotive Vehicle Parts & Accessories Experts
Rigger DeBusk
Bill Boyd
Richard Warren
Richard Warren
Are you a Crl Automotive Vehicle Part and Accessory Expert? Answer questions, earn points and help others
