I have not got my manuel for my remote and need a code to get it to work on a samsung Television set that is about 8 years old, the remote # LSSQ0375.
I have a Panasonic remote and need to program my TV with it but no code book. Who has the code book with Magnavox TV code in it? Thank You Dia
Hello I need codes for a SONY TV do you haved please....
I have the manual. The code number should be 14 for samsung.
You need to hold down TV button on remote and enter the code.Good luck.
Universal remote allow you to control multiple
electronic devices with a single remote. You can use the remote to work
your TV,DVD player, cable boxes and other devices from the comfort of
couch.Philips is a popular manufacturer of universal remotes.to program a
GE remote for SONY TV,you will either need to input the device
code or perform a code search
direct entry
first.turn on your TV manually. next.press down
and hold set-up on the remote.the red indicator light will stay
lit.after that.press the TV device button to let the remote know you
wish to program a television then.enter your device four digit codes on
the remote..GE list several codes for SONY television including 0002 0006 0007 0018 0107 0114 0310 0312 0502 0601 0704 0719 0803 0806 0810 0901 0911
..if your remote needs 3 digit codes remove only the
number zero in the beginning of the codes finally.test the remote to
ensure it works.with the turned on,press the channel button and see if
the TV responds..if it is work the remote programmed and you are done,if
it doesn't work try the different code......
IF THIS SOLUTION HELPS YOU PLEASE DON'T FORGET TO RATE MY ANSWER THANK YOU
It would be foolish to pay for the solution of this minor issue I would be better off buying a new controller,
Thanks for the solution avirame.
breadman1
I got a Panasonic LSSQ0375 unversal remote from my friend and he lost the code book. So if anyone can give me the codes or give me a site to get the codes from I would be very thankful!
LSSQ0375 = same remote...
not samsung tv... sony tv instead.
