Refrigerators Logo
Emily Mejia Posted on Sep 17, 2019
I can’t find where to change the water filter on my Maytag plus refrigerator model msd2766ges
McDaver
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Sep 17, 2019
 McDaver
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
4466
Points
23
If you go to https://www.filtersfast.com/Maytag-Refrigerator-Water-Filters-cat.asp
It will show you styles of Maytag Refrigerators. If you click on the one that matches your style, it will show you possible areas the filter is located. You can then look in those areas. Once you locate it, then you can then identify your filter part # and replace if needed. You can also go to Maytags website and look up your model and find the manual. The manual will likely tell you where the filter is and what the part number is.
5 Related Answers
Anonymous
  • Posted on Aug 24, 2008
SOURCE: water filter leaking
This happened to me and was the o-ring, the cup is sealed by the o-ring and in my case I did not realise it dopped off after I unscrewed. Either your o-ring is missing or needs replaced as it is worn out.
Anonymous
  • 700 Answers
  • Posted on Apr 03, 2009
SOURCE: Change water filter for a maytag plus refrigerator
press the light switch button inside of the refrigerator five times.
jvernice
Joseph Vernice
  • 63 Answers
  • Posted on Jul 29, 2009
SOURCE: bad smelling water
The water lines are contaminated with bacteria and/or mold. This is a problem with many refrigerators. You need to turn off water and disconnect the feed line and filter. Mix 4 ounces of Clorox(R) in 1 gallon of water and pump it through with a NEW garden sprayer. You can remove the wand and clamp it onto the water inlet. Activate the dispenser while you pump the bleach through the system. Once bleach starts coming out the dispenser, vent the garden sprayer (de-pressurize), Let the bleach sit for 15-20 minutes. Re-attached water using a brand new filter (do not use the old filter and do not put bleach through filter). Run water until no chlorine odor (it can be a while). This process needs to be done at least once a year.
Anonymous
  • Posted on Aug 27, 2009
SOURCE: HOW TO TURN OFF THE "CHANGE WATER FILTER LIGHT"
Press light and lock and hold until light blinks release and the light will go out
Anonymous
  • Posted on Aug 29, 2009
SOURCE: How do I turn off the "change water filter light" on the door? I just changed the filter
Hold the lock and light buttons in together for 3 secs. or so and the light will go out! You don't even need to change the filter to do this.
1helpful
Side by side Maytag frig.dispenser water is slow. model MZD2665HEB I changed water filter .water flow is slower than normal.
When a water filter is replaced alot of air gets compressed in the plumbing and the filter which will cause a temporary reduction in the flow rate until the air is bled out through normal use.
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house in June. The change filter light came on a few weeks ago and I can't get it...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house the change filter light came on and I can't get it to go off. How do I reset the change filter light (it's not time to change the filter)? The model # is MSD2732GRW and I don't have a manual for this refrigerator. Thanks!!
8helpful
I changed my water filter and now i need to turn out the filter warning light.
WATER FILTER CHANGE REMINDER
(Select Models)
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER
indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Note: The Water Filter Reminder will
operate if the filter bypass is in place.
Please rate me!
Thanks, Sea Breeze
1helpful
NO manual for Fridge.
I can get the service manual for you. Here is what the manual tells you on page 101.
(Select Models)
FILTER
Thanks, Sea Breeze
11helpful
Maytag msd2454gr refrigerator how turn filter light off after replacing filter?
FILTER
2answers
Maytag Model MSD2651HEW - Changed Filter and
try checking your water resevioir it sits behind the drawers and sometimes gets ice crystals in it
take a hirdryer to the water lines that are exposed for a few minuts this might help
49helpful
2answers
Turn off the change filter light on maytag refrigerator
For my Maytag Refrigerator Model # MSD 2756 GE, I had to hold the "Light" & "Lock/Unlock" buttons simultaneously until the "Change Filter" light went off instead of the "Water" & "Lock/Unlock" buttons.
11helpful
1helpful
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
