You need to have an ohmmeter. Then you need to get access to the heater terminals. Depending on the model, it could be located near the front of the dryer or back of it. UNPLUG the dryer before removing any screws. When you fid therheater element, measure the resistance between the 2 main terminals (you don't have to disconnect any wires before measuring). You should measure somewhere between 9 and 20 ohms. If that's good, then measure between 1 of the terminals and the case (ground connection) of the heater. If you measure less than 100 ohms, then you may have an internal short in the heater element. To make sure, disconnect the wires going to the heater element and re-measure. Now you should have a very hightresistance measurement, more than 100,000 ohms to infinity. If you measure less than 1000 ohms you either have a short inside the heater, or something that got inside and got burned up, producing a carbon path for the electricity.
If the heating element checks good, then look of an open thermal fuse.
SOURCE: Electric Clothes Dryer Problem
if the dryer worked fine before with the element not staying on when you open the door, etc, then what you have done is a very common mistake to make, you must have dislodged a wire off, or maybe placed one back in the wrong place, its a very easy error to make, which is why when removing parts for repair on any appliance you must make very detailed notes, better still take digital photographs with a digital camera double check any wires etc, don't worry i am a retired appliance engineer and even we can make this mistake
SOURCE: Clothes dryer not producing heat
Check voltage at the receptacle first. The motor and timer operate on 120VAC. The heating element requires 208/240VAC to operate. Remove power from the unit. You can check the heating element, thermostats and thermal fuses using an ohm meter across each components terminals with one wire removed. The thermal fuses and thermostats should read zero ohms. The heating element will read low ohms (20 to 40). Successful heater operation still depends on the motor centrifugal switch being closed. Depending on the model, you need the heat circuit in the timer or electronic control to be closed.
I hope this helps you.
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
SOURCE: replace electric heat element in Amana dryer
You can find an exploded view of the dryer on searspartsdirect.com. Looks like you access from the rear service panel.
SOURCE: what is cost of heating element of dryer
Prices vary by model number and parts resources. The element usually cost somewhere between $30 and $50. Here's a few websites you can use for reference to get an idea of how much a replacement element can cost:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed also have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need.
NOTE: In many cases, if you are experiencing a no heat problem, the heating element is NOT the problem. The heating element has protection devices that are designed to regulate the heat temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
If you have already diagnosed your problem, great. If you need to reassurance so you don't spend money you don't have to, the following links can give you some tips on how to troubleshoot a dryer:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
If you have any questions, please post back with your MODEL NUMBER so I can accurately determine how your dryer is configured. I hope you find this information helpful.
