Question about Exercise & Fitness
My Fitbit watchm is just showing a light black screen with lines running down it and won't chargen
2 Suggested Answers
6ya staff
SOURCE:
jrweighing
jrweighing
  • 183 Answers
SOURCE: a black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Posted on Mar 03, 2010
How do I delete my Fitbit mini from my account and upgrade it to a HR2 fitbit
How to delete a tracker from the Fitbit app for iPhone and iPad.
  1. Launch Fitbit from your Home screen.
  2. Tap on the Account tab. ...
  3. Tap on the device you want to delete.
  4. Swipe up to scroll down to the bottom of the page.
  5. Tap on the Remove This [Fitbit] button. ...
  6. Tap on the Remove This [Fitbit] button in the confirmation dialog.
How to add, replace, and delete trackers with Fitbit for iPhone and ...
https://www.imore.com/how-add-replace-and-delete-trackers-fitbit-iphone-and-ipad
https://www.imore.com/how-add-replace-and-delete-trackers-fitbit-iphone-and-ipadFeb 5, 2016 - How to delete a tracker from the Fitbit app for iPhone and iPad. Launch Fitbit from your Home screen. Tap on the Account tab. Tap on the device you want to delete. Swipe up to scroll down to the bottom of the page. Tap on the Remove This [Fitbit] button. Tap on the Remove This [Fitbit] button in the confirmation dialog ...
How do delete my Fitbit mini from my account Google Search
Jun 11, 2018 | Exercise & Fitness
Why do rockets and shooting stars go off and the numbers 2123 appear on my Fitbit screen
you reached the preset goal!
Celebration animations meaning - Fitbit Community
https://community.fitbit.com/t5/Charge-2/Celebration-animations.../td-p/1686677
Dec 11, 2016 - 5 posts
I noticed Charge 2 shows different celebration screens when you reach your goal and they don't seem to be random. Usually I get the rocket when I. ... So I guess there should be a meaning. there are still boubles (maybe reaching goal before evening?) and the star pattern I've no idea why it appears.Missing: shooting ‎numbers ‎2123
12 Not-So-Obvious Things to Know About Your Fitbit Tracker - Fitbit Blog
https://blog.fitbit.com/fitbit-help/ Jan 13, 2017 - Dive deep into your data. The detail screen you're brought to when you click on a dashboard tile isn't static either. For many, you can scroll through the top panel to see more data analysis and even get one-week, one-month, three-month, and one-year averages. You may also be able to click on the ...Missing: rockets ‎stars ‎2123
Apr 22, 2018 | Exercise & Fitness
My fitbit 2 charge is showing wrong time and date.how do I reset it
completely shut down the phone/device you sync with and the Fitbit. When re-starting, make sure there are no other devices that are trying to connect to the Fitbit, and that the app on the device you're syncing with is up to date.
this usually works. If not - contact Fitbit Customer Support.
Jan 09, 2018 | Exercise & Fitness
I just want to know how to set up my fitbit
Hi Alan.
not sure if this is what you are asking.
How to sign up for Fitbit in the Fitbit App for iPhone and iPad.
  2. Tap Join Fitbit.
  3. Scroll through the list and tap on the Fitbit device you have. ...
  4. Tap on Set up your Fitbit button.
  5. Tap on the Let's Go button.
  6. Swipe up or down to set the the big number in the middle to your height.
More items...
How to set up and start using Fitbit for iPhone and iPad ' iMore
https://www.imore.com/how-set-and-start-using-fitbit-iphone-and-ipad
or go to this link.
how to set up my fitbit Google Search
Nov 04, 2017 | Exercise & Fitness
Can the screen cover on a A Fitbit HR Charge be replaced
It can!
(6-Pack) EZGuardZ Screen Protector for FitBit Charge HR (Ultra Clear ...
https://www.amazon.ca/6-Pack-EZGuardZ-Screen-Protector-FitBit/dp/B00SVW2DPO
  1. Cached
Pack of 6 Brand New EZGuardZ™ Screen Protectors; Precision Cut for your FitBit Charge HR, NO Cutting Necessary; No worrying about sticky residue; Thin, ...
Screen Protector And How To Get Scratches Out - Fitbit Community
https://community.fitbit.com/t5/Charge-HR/Screen-Protector-And-How.../835469
  1. Cached
Jun 21, 2015 - If you have a Fitbit Charge HR, I highly recommend getting a screen protector. The plastic screen is not strong at all, and it is also very easy to.
Best screen protector brand for Charge 2. - Fitbit Community
https://community.fitbit.com/t5/Charge-2/Best-screen-protector...Charge.../1543173
  1. Cached
Sep 2, 2016 - Wendy ' California. Retired Classic, Ultra, Charge,Charge HR. In use One, Charge 2, Surge, Blaze, Alta and Aria ' Windows 10 ' Android Moto ...
Amazon.com: XtremeGuard™ Screen Protector for FitBit Charge HR ...
https://www.amazon.com/XtremeGuardTM-Screen-Protector-FitBit-Charge/.../B00SV...
  1. Cached
Buy XtremeGuardTM Screen Protector for FitBit Charge HR (Ultra Clear): Screen Protectors - Amazon.com ? FREE DELIVERY possible on eligible purchases.
FitBit Charge & FitBit Charge HR Watch Front INVISIBLE Screen ...
https://www.amazon.com/INVISIBLE-Protector-included-Protection.../B00UMAXNJS
  1. Cached
Buy FitBit Charge & FitBit Charge HR Watch Front INVISIBLE Screen Protector (Front Shield included) Military Grade Protection Exclusive to ACE CASE: Screen ... screen cover on Fitbit HR Charge Google Search
Nov 16, 2016 | Exercise & Fitness
Can the screen be replaced on a fitbit charge hr
  1. Cached
  1. Cached
  1. Cached
  1. Cached
  1. Cached
How do i charge up my fitbit?
      To charge your tracker:
      1. Remove your tracker from the wristband:
      2. Insert your tracker into the charging cable. ...
      3. Insert the charging cable into a USB port or UL-certified USB wall charger.
      4. Your Flex's LED indicator lights will pulse to show the battery level every few seconds.
      More items...
      Help article: How do I charge my tracker? - Fitbit Help
      https://help.fitbit.com/articles/en_US/.../How-do-I-charge-my-tracker Fitbit
    Feedback
    https://help.fitbit.com/articles/en.../How-do-I-charge-my-tracker
    FitbitDec 12, 2015 - To charge your tracker: Remove your tracker from the wristband: Insert your tracker into the charging cable. Insert the charging cable into a USB port or UL-certified USB wall charger. Your Flex's LED indicator lights will pulse to show the battery level every few seconds.
    Fitbit Help - Getting Started
Jan 21, 2016 | Exercise & Fitness
Lost fitbit,bought new one and it will not sync
You must use the app or Fitbit Connect to set it up. The Bluetooth settings screen on the phone or computer will not work.
Mar 03, 2014 | Fitbit One Activity Tracker, Black
My powered USB port on my Dell Latitude D410 shorted out. Can this be repaired/replaced?
The USB plug will need to be removed from the computer, if luck is with you the computer will work, if no part is available, use a none powered USB hub on a spare port if available to run your applications.
Jun 23, 2012 | Dell Latitude D410 Notebook
Exercise & Fitness Logo
47 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
