SOURCE: Konica Minolta C353 has a C4551 error, how do I fix it?
try replacing the imaging unit with a new one not a reset imaging unit
SOURCE: Konica Minolta C353 - Error Message C-4554
The C-4554 error identify a Laser Malfunction (K).
You could check flat cable that connect laset to logic unit.
Chech all laser K cables/connections.
If persist you have to change Lasers group.
Bye.
Testimonial: "Thanks for this helpful reply!!"
SOURCE: i am having this error message with my konica
This is a tcr fault with the black i/u check the toner or i/u if tone has just been replaced check the seal on the unit sometimes the break and no toner comes through =if not look at replacing the i/u
SOURCE: My Konica Minolta Bizhub C353 is showing a C-4553
Hi this error is a laser malfunction withe the yellow assembly you will need to change the yellow print head unit what you can do is take out the print head unit assembly swap the yellow print head unit with the cyan unit then you should get error c-4552 then you know the unit is faulty
this will fix your issue
